need help on head gasket
Old Aug 19, 2014 | 04:19 AM
BenS579's Avatar
Default need help on head gasket
Hi all, im not very good in tech and i need some advise. From what i knew my b18 darton sleeves, 85mm bore and stroke 95mm, eagle crank balanced, buddy club spec 5 cam,bleeder tank run direct w/o pcv valve. Thats all i know in my ride.
AND Just did an top overhaul due to blown headgasket and its the 3rd gasket blown in 4 mths.When open up, The crank shaft bearings are worn and its less than 2yrs old,piston ring,motion assym,valve guides,stems etc... some wear and tear so had to change as well. And guess what, head gasket blown again....!!! Im at my wits end...
Old Aug 19, 2014 | 05:09 AM
Runnerdown's Avatar
Default Re: need help on head gasket
MLS head gaskets do not just blow. If you are replacing them that often you clearly have an issue with improper finished or warped sealing surfaces, sleeves sinking...something is wrong there.
Old Aug 19, 2014 | 08:44 AM
F22Master's Avatar
Go to JDM importer.
Buy stock B18C-R eninge.
Install into your car.
Drive.
Old Aug 19, 2014 | 10:40 AM
boostjunkie757's Avatar
Originally Posted by F22Master
Go to JDM importer.
Drive.
lol..
that is one way of doing it..
id add enjoy the stock driveability factor to the statement as well.
Old Aug 19, 2014 | 03:35 PM
Turb0wned's Avatar
Go to JDM importer.
Drive.
Best advice lol.
boosted92
Jun 9, 2005 02:32 PM
riceball777
May 17, 2004 07:10 PM
Speed PHreak
Nov 20, 2002 08:00 AM
