2000 accord not starting
I have not drove it for a couple days and went to start it up today and it would not run. Now the cooling fans kick in right away when you turn the key and I went to check the fuel pump fuse and when I pull it out the fans shut off. car has the 3.0 L V6. Any thoughts?
What do you mean it won't run ? Can you be more specific. When the ac is on and the compressor is cycled on the fans will run so if you have the ac on when you start the car the fans will start up. You probably didn't realize this before.
Fielduser
K Series
Mar 16, 2017 04:51 AM
neb236
Jul 20, 2010 11:01 AM
