High Lift H22A camshaft installation issues... anyone else have this problem ?
Old Aug 18, 2014 | 01:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default High Lift H22A camshaft installation issues... anyone else have this problem ?
Just installed a set of camshafts with .509" lift on the VTEC lobe in an otherwise stock 2000 H22A4 head casting... and after spinning the engine over a few times I noticed some slight resistance on occasion. Further investigation has revealed that the VTEC lobe is making contact with the bottom of the aluminum oil rail/bar bolted down across the cam caps.
My first thought was to remove the oil rails and machine a small recess in the middle of the oil rail slightly wider than the VTEC lobe on the camshaft to allow the proper clearance when the lobe peak passes by.
Has anyone else run into this... and if so, what did you do to fix it ???
Old Aug 18, 2014 | 05:48 PM
DDTECH's Avatar
Default Re: High Lift H22A camshaft installation issues... anyone else have this problem ?
You can machine them and you'll be fine - There's a lot of people that are doing this to clear larger camshafts.
Old Aug 19, 2014 | 02:30 AM
bluehbcivic's Avatar
10 Year Member
Yeah ive seen this a couple times grind these down lol
Old Aug 19, 2014 | 07:12 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Thank you both for the responses... I will get to grinding !!!
Old Aug 20, 2014 | 08:38 AM
OMG's Avatar
OMG
which cams
Old Aug 21, 2014 | 07:33 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Crower Stage 3P's (part # 63423P-2)... just like the old stage 3's I used to have, only with .040" more lift in VTEC. I have machined the contact areas and re-installed the oil rails. She sounds just fine now. Time to strap her down to the dyno...
Old Aug 21, 2014 | 07:48 AM
OMG's Avatar
OMG
nice, in for results
Old Aug 23, 2014 | 05:01 PM
Ferarrikiller's Avatar
definitely interested in seeing what these make.
Old Aug 23, 2014 | 05:17 PM
SpoonH2B's Avatar
in for results !!!
Old Aug 28, 2014 | 10:53 AM
Srxboy's Avatar
how do these cams compare to skunk2 pro 2s?
dxcivic121
Nov 25, 2012 01:07 PM
cpmike
Jul 3, 2009 12:00 AM
venger
Jul 6, 2005 11:10 AM
EsQueue
Apr 29, 2004 12:06 AM
lePetitePrince
Feb 16, 2003 02:37 PM
