96 Civic/b18b1 swap - Code 63 Won't Go Away
Old Aug 18, 2014 | 10:26 AM
FeelTheBass's Avatar
Default 96 Civic/b18b1 swap - Code 63 Won't Go Away
Car: 1996 Civic Hatchback CX w/ b18b1 swap
My exhaust setup is stock b18b1 header, Civic EX OBD2 cat, EX Midpipe, Stock Muffler
When I swapped in the car, I extended the O2 sensor wires myself (dumb idea, I know). After realizing it was a bad idea, I bought the harness's because I was throwing CEL's for both O2's.
After I installed both O2 extension harness's (shoutout HondaPartsHero), my primary O2 CEL went away, but my secondary O2 was still throwing Code 63.
I replaced the secondary O2 sensor, because I wasn't sure if it was faulty or not. After replacing the secondary O2 sensor, my CEL has returned. Not sure what to do now, someone was telling me it could be my cat because it's from a civic not integra.
Any Input is Appreciated, Thanks!
Old Aug 18, 2014 | 01:35 PM
Default Re: Code 63 Won't Go Away
bump anyone?
Old Aug 18, 2014 | 04:53 PM
bump
Old Aug 18, 2014 | 05:06 PM
joey1320's Avatar
You will need to buy a DVOM, learn how to use it and search for the ecu pinouts for the secondary o2 sensor. Perform a voltage drop test and a continuity test from the ecu to the sensor.
Report back
Old Aug 18, 2014 | 09:45 PM
I needed to buy a multimeter anyway, what would these tests tell me Joey?
Old Aug 19, 2014 | 02:27 AM
HondaPartsHero's Avatar
Technical Hero
Originally Posted by HondaPartsHero
Old Aug 19, 2014 | 12:06 PM
joey1320's Avatar
The tests will tell you if the wiring is good. I dont have the Honda diagnosis tree chart in front of me, but if you find it, I'm sure it will tell you what resistance values the oxygen sensor should have. That will tell you if the sensor is compatible with your ecu requirements.
Edit: just saw the diagnosis tree posted above me, it wasn't coming up on my phone.
Old Aug 19, 2014 | 12:07 PM
Thank you, HondaPartsHero, I will need to stop by HB and pick up a multimeter.
Question: Does my Civic EX Cat have anything to do with this CEL? It's an Integra engine with an EX Cat, if I put in an integra cat would that do anything?
Thanks.
Old Aug 19, 2014 | 12:08 PM
Alright, sounds good. Off to harbor freight soon.
Old Aug 19, 2014 | 12:28 PM
joey1320's Avatar
Thanks.
Not unless your converter is damaged or ruined. A converter takes any unburn fuel molecules(easiest explanation) and reburns them or changes their form into a harmless form like nitrogen, Carbon Dioxide or water vapor. Again this is the 1st grade class version...
Anyways, if your converter is of good quality and in good health, it should be able to handle the task. If it was already weak or deteriorating, then it could cause issues. But usually what happens to a converter is the "honeycomb" material nurns/melts into a solid state and blocks your exhaust flow, creating a 'bogging' feeling when trying to accelerate.
joey1320's Avatar
Dont go to Harbor Freight, please get a better quality unit, even if its a Craftsman one...
Old Aug 19, 2014 | 01:51 PM
Hmm alrighty, thanks for the easy lesson Maybe I'll check out Sears.
Old Aug 20, 2014 | 12:23 PM
Alright here are the results so far,
Resistance between male terminals 3/4 - 13.1 Ohms (OK)
Continuity between male terminals 3/4 individually - Both No Continuity (OK)
This is where i started to get confused,
Voltage Between Female Terminals 3/4 - the voltage was jumping all over the place, it never was set at one number; does this mean I am getting voltage or not?
Old Aug 20, 2014 | 12:34 PM
Former User's Avatar
This is a very rare case where HondaPartsHero posted the wrong troubleshooting diagrams. The tests for code 63 are different.
What ECU?
Old Aug 20, 2014 | 01:52 PM
Default Re: 96 Civic/b18b1 swap - Code 63 Won't Go Away
Ha alright, my ECU is a OBD2A P75
Old Aug 20, 2014 | 01:59 PM
Which of the three OBD2 codes (P0137, P0138, P0139) is thrown?
Old Aug 20, 2014 | 02:01 PM
Unfortunately, I don't have a scanner. I was using a paper clip to jump the connector and watch the blinks.
Old Aug 20, 2014 | 02:02 PM
A free service at AutoZone is pulling CEL codes with a code reader.
Old Aug 20, 2014 | 02:06 PM
Alright I'll drop by there and report back ASAP.
Going to try to BAR my car tomorrow since I already booked the appt. 2 weeks in advance. Let's hope i can get this figured out.
Old Aug 20, 2014 | 03:04 PM
Alright, just got it scanned and it is P0137.
Old Aug 20, 2014 | 03:46 PM
Do the short test at terminal 1 (Wht/Red wire) of the secondary O2 sensor connector (female terminal/wire harness side).
Old Aug 20, 2014 | 04:11 PM
My terminal 1 is red/yellow and terminal 2 is red/white, not sure if that matters, but i did the short check on the red/white wire.
Voltage .3 or Below W/ Engine at 3k RPMS - Yes
Voltage .3 or Below W/ Engine at Idle - Yes
Disconnect Connector D at ECU, Continuity Check Terminal 1 W/ Body Ground - YES
I assumed grounding the multimeter to the negative terminal of the battery would suffice. So this means I have a short in that wire? How can i fix that?
Thanks for the help thus far.
Old Aug 20, 2014 | 04:15 PM
Terminal 1 is the Wht/Red wire. You are misinterpreting the connector diagram. Terminal 2 is a Red/Yel wire. Terminal 3 is a Blk/Yel wire. Terminal 4 is a Blk/Whtwire.
And you are not doing a short test, which measures Ohms or continuity not voltage.
Old Aug 20, 2014 | 04:20 PM
Im using the wiring harness from my stock d16y7 obd2a.
I thought I was supposed to be doing a short test, or are you saying that I'm doing it incorrectly? I'm a tad confused.
Old Aug 20, 2014 | 04:23 PM
Carefully read my last post and the troubleshooting diagram. You are not doing a short test when you measure voltage.
