B series cams idefication
Old Aug 17, 2014 | 03:20 PM
sean-sports's Avatar
Default B series cams idefication
I bought a crx that was burning oil. Pulled it apart and found valve stem seals bad but when I was pulling it apart I found aftermarket valve springs and retainer which I think they are blox and a set of cams with no markings on them except a stamp H in the cast. My question is does anyone know what these cams are. I've search and I know blox has no marking but none of the ones that I have seen in the search have an H in the casting. Hope someone can and thanks in advance.
Old Aug 17, 2014 | 10:12 PM
93egSLEEPER's Avatar
Default Re: B series cams idefication
Take a picture of the ends on them. The end opposite the cam gear.
Old Aug 18, 2014 | 12:23 AM
ef2_civic's Avatar
Looks like a stock marking to me. But I could be wrong
Old Aug 18, 2014 | 06:31 AM
TheShodan's Avatar
Moderator
Looks stock to me. The Drilled hole gives a BIG clue for a steel OEM cam
Old Aug 18, 2014 | 05:26 PM
Those journals have a ton of wear, at least IMO from the pics.
OP can you upload better pics to share?
Old Aug 18, 2014 | 05:56 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
They're tiny whatever they are.
ITRs at best, GSRs most likely.
hewland
Jan 3, 2018 01:50 PM
rorik
Sep 19, 2007 05:41 PM
HCivic45
Jul 21, 2005 10:56 PM
keebler65
Mar 4, 2003 07:57 PM
GumballNA
Sep 20, 2002 03:39 PM
