2014 Pilot
Does anyone know if you have to come from behind the fog light housing on the 2014 pilot to change the bulb? it doesn't appear you can unscrew the housing from the front like on the older ones. Can anyone chime in?
For reference, its a 2014 pilot touring
Well, I managed to change the bulbs but yes I did come from behind. After removing the fog light bezel from the front, you will notice that the fog light housings are actually screwed in from behind. To access behind the fog light, I had to come from the corresponding wheel well. I had to cram my hand and arm through the plastic lining and manipulate the bulb from behind. It was a pain but it got done. I assume that would be the only way to change the bulb unless you pull the entire front bumper cover off.
animated_life
Dec 27, 2003 12:03 PM
