Honda Accord 1993 won't start
About three months ago my 93 accord started having problems starting. I've already changed the relay, spark plug wires, distributor cup, coil, and starter
None of these seemed to help, except when I did change the starter, I was able to get the car to start and run for about five minutes, but it shut off when I revved the engine (I suppose it was after a certain rpm that it shut off) and I have not had any luck getting it to start back up again ever since.
Would anyone happen to have any suggestions? I figure it cant be too hopeless seeing as how I at least got it to start running even for just under five minutes. I appreciate any feedback in advance.
If you're sure about spark and fuel then the only thing left to check is the compression, that's assuming your timing right and your dizzy isn't off by 180, although it would never have started had that been the case.
You need spark, fuel, air and compression to start a car that's in time.
SentinelK151
Aug 6, 2017 08:42 AM
