1998 Honda Civic LX Cranks but no spark there is fuel
Old Aug 15, 2014 | 05:14 PM
Rokle's Avatar
Icon6 1998 Honda Civic LX Cranks but no spark there is fuel
I have a Honda Civic LX 98 i ran it for a few hours went inside came back out and it would crank but wouldnt start so i knew it was an ignition problem, we replaced the coil and the ICM and after we replaced them we noticed the car wouldnt crank over but it was before there is still no spark but we are getting fuel please help! *When we tested the old ICM we did not get a reading from the Negative (white/blue)wire* havent tested the new one
Old Aug 15, 2014 | 05:33 PM
tony_2018's Avatar
Fish Twig
Default Re: 1998 Honda Civic LX Cranks but no spark there is fuel
What were you doing prior to it running for a few hrs?
Old Aug 15, 2014 | 05:59 PM
Former User's Avatar
Is fuse 9 blown?
Old Aug 15, 2014 | 06:12 PM
Rokle's Avatar
All fuses have been checked and are good, and I use it daily run it about 80 miles per day
before running around town for a few hours it was parked for the night after running it i went inside with my girlfriend for about 2-3hours came back out and it would crank i hear the fuel pump kick on but no spark or start
Old Aug 15, 2014 | 06:16 PM
Did you voltage test fuse 9?
Did you check whether battery voltage reaches the Blk/Yel wire terminal in the distributor connector?
Old Aug 15, 2014 | 06:31 PM
timetosleep's Avatar
Hello, sounds to me like you might have more than one issue, you say the vehicle doesn't crank? To me that's the first thing you need to address, you will not get spark until the motor physically cranks, is it as simple as the starter? Maybe it's a stick shift and you have a bad clutch pedal sensor or a dead battery? Either way it will have to crank before spark is created, if it's stick shift you can try to pop start the vehicle? Let me know I'd be happy to help.
Old Aug 15, 2014 | 06:45 PM
Rokle's Avatar
its cranking now im sorry and the blk yellow wire reads battery voltage but my yellow blue whire reads 0.00ohms
Old Aug 15, 2014 | 06:47 PM
It's actually Yel/Grn. Describe how you did the Ohm test..
Old Aug 20, 2014 | 07:02 PM
Rokle's Avatar
Replaced the ICM everything reads right the car now cranks and there is spark now, but the spark is weak mechanical timing and ignition timing are both spot on sorry for taking so long to reply
96CivicEXSedan
Feb 19, 2019 07:23 AM
Samhoe144
Oct 23, 2014 07:25 AM
desiromeo812
Dec 18, 2008 05:35 PM
prem0626
Oct 20, 2008 11:54 AM
