Problem with honda accord 1990 distributor
In another thread https://honda-tech.com/forums/showth...409&p=49882796
I am opening a new one becasue in the reply i cannot upload photos.
the advise was to change my distributor o-ring. So I went to NAPA and got the o-ring for honda accord dx distributor.
Went back , put the distributor apart and it didn't have any o-ring...so the leaking was there!....and the O ring doesn't fit . It is to big. No matter how I put it, when I put in the distributor in place, it goes all the way back. IT doesn;t stay at place.
I guess the distributor I have is not authentic?
I am attaching some pics and info ...
The other info is what is written on the alternator:
TD-31U 3601 in the metal part
TEC honda PP~T in the plastic part.
Please help
Please help
The oring looks like its the correct size. I dont really understand how it can slip back off the shaft when you install the distributor. I would suggest going to the nearest honda dealer and getting an oring from them.
Well, you see the black thing? If taht is teh o-ring I thought it was not. It is so worn out it didn;t even feel like rubber so I tried the o-ring between the o-ring and the metal part, that is why it didn;t fit. I will have to take the old out with a sharp screw driver or a knife.
I will do it tomorrow.
Mine was very hard and I couldn't cut it with a knife. I had to chisel it out with a small screw driver and a hammer. It broke apart and came out in pieces. The new seal went on easily and the leak stopped.
