TN: 84mm Sleeved/Stroker Engine Swap
Complete B17 motor swap for sale. 84mm sleeves installed by Golden Eagle, Headwork done by DFE in Florida, Brian Crower 84.5mm stroker kit, CP 12:1 pistons, Buddy Club Stage 4 cams, Supertech valve train, Hondata S300, PLX wideband, Competition Clutch stage 2 clutch and lightweight flywheel, Moroso large capacity oil pan, complete list of parts below.
Everything was new when motor was built, I just checked inspected and re-torqued everything, bearings are like new, compression is within 8psi across the cylinders.
$Sold
Engine:
B17 Block & Head
Golden Eagle Sleeves 84mm
Golden Eagle Oil Squirter Deletes
Brian Crower Stroker Crank 84.5mm
Brian Crower 4340 Rods
ACL Bearings
CP Pistons 12:1
CTR Pulley
Golden Eagle Head Gasket
ARP Head Studs/Rod Bolts/Flywheel Bolts
Type R Oil Pump
DFE Ported Head
Supertech Flat Valves
Supertech Dual Springs and Retainers
Buddy Club Stage 4 Cams
Skunk 2 Pro Cam Gears
RC 370cc Injectors
Toda Timing Belt
AEM Fuel Rail & Regulator
Ported P61 Manifold
AEM Intake
Moroso High Capacity Oil Pan
Hondata S300 (OBD1 P61 ECU)
PLX M300 Wideband with Bosch Sensor
Denso Iridium Plugs
MSD Super Conductor Wires
Y1 Transmission
Competition Clutch 2200
Competition Clutch 11lb flywheel
Axles and Halfshaft
$Sold
Engine:
B17 Block & Head
ACL Bearings
CP Pistons 12:1
CTR Pulley
Type R Oil Pump
DFE Ported Head
RC 370cc Injectors
Toda Timing Belt
Ported P61 Manifold
AEM Intake
Denso Iridium Plugs
Y1 Transmission
Axles and Halfshaft
Aye sorry for the late responses, I thought this was setup to email me when people posted.
I've got a couple people that are in line to pay but if they don't come through this weekend I'll let you know.
HybridKOOP
Oct 24, 2003 02:02 PM
