Temp gauge with warning light install problems
First off its a 94 hatch with a jdm b16
I ordered a water temp gauge with warning light
It has 2 sensors 1 for the gauge which I hooked up at the thermostat housing and it has a sensor for the warning light
It has. 1/2 inch pipe thread adapter which won't worki emailed him and he says they offer a 3/8 adapter but doubts that will work too.
I notice another port on my cylinder head where there is an unused sensor
What's my options here?
Anyone know an adapter or maybe a t fitting to connect both sensors?
You don't need that ****, you need to replace those sensors on the head, you should be checking for continuity on those sensor wires first before confirming that its the sensor that is bad.
stocker2shocker91
Mar 24, 2008 01:19 PM
