FS: (MD) Civic Integra B16 B18C GSR SI Parts *For Sale*
I have receipts for mostly all these b16 engine parts and if you are interested I can include in the sale of ANY Item below.
text me for pictures, two40-605-397five
TEIN basic coilover suspension for EG/DC - $600
Comes assembles with top hats and Front EG forks
Used for 3k miles and then removed from vehicle
Excellent condition!!!
96 GSR OBD2 Cylinder Head - $180 obo
Valve Damage and will need machine shop work.
Includes GSR OEM Intake Manifold, Cam Caps, LMA's,
rocker shafts & arms & Head Studs.
B18C GSR Transmission w/ ITR LSD - $600 firm
I rebuilt this transmission and replaced every gear/synchro/Sleeve (with Honda
OEM parts) Except for the 3-4 sleeve. If you pop this open and change the 3-4
Sleeve then you will have a brand NEW transmission. My loss your gain!
B18 LS Throttle Body - $50
96 GSR B18c Cams - $100
B16 ARP Headstuds - $100 obo.
B series Clutch Kit - $80
USED ITR Pressure plate w/ Exedy Street Disc
Fidanza Lightened Flywheel - $80 obo.
B16 Block Rotating Assembly - $400 obo.
Includes: JDM CTR Pistons on B16 Rods with ARP Rod Bolts,
OEM Honda B16 Crank, OEM Honda Crank and Rod Bearings
all in perfect condition. Block was milled to low by machine
shop and leaks at the head gasket so parting out internals.
Was only used for 6k Miles.
B16 / LS Block Girdle conversion kit - $150
Includes: GSR/ITR style Block girdle & OEM ITR Crank cap bolts(x6)
This kit will bolt up directly to ANY B16 or LS Motor without Modification
and greatly strengthen your bottom end and allow higher reving.
ITR B18C OEM Oil Windage Tray -$40
ITR B18C OEM Oil Pick-up - $40
ITR B18C P72 Oil pan - $80
SKUNK2 Front Civic Integra Camber Kit(One side needs new ball joint)pair - $50
94-01 Integra GSR B18C1 OEM Intake Manifold w/ Gaskets(BARE) - $40 obo
92-95 Civic GREY Steering Wheel & Air Bag - $20
92-95 Civic SI Seats Charcoal - $100
92-95 Civic / 94-01 Integra Black Steering Wheel & Air Bag- $40
B16/B18/B20 Hydro Transmission(Clutch Housing ONLY) case *BARE*- $30 obo
B16/B18/B20 Hydro Transmission case *BARE*- $80
B16/B18/B20 OEM Flywheel bolts(USED) - $15
OEM B16 Oil Pan w/ Password JDM Baffle - $90 obo
OEM B16A VALVES - $30
OEM B16 (Lost Motion Assemblies) LMA's - $30 obo
NEW B16 aftermarket Timing Belt - $30
OEM Integra GSR B18C Intake Valves - $20
Picture available upon request
Located in the Aspen Hill Area 20853 for pick up
Shipping available and Paypal verified Business User
Text me @ Two40-605-397FIVE
__________________
__________________
ProjectEGSiR
Mid-Atlantic (Sales)
30
Sep 15, 2014 11:43 AM
A51_RPS13
Northern California (Sales)
13
Nov 15, 2008 01:42 AM
GQej1
Oct 9, 2008 09:35 PM
