tube seal leaking issue
Old Aug 12, 2014 | 09:04 PM
90RioEF's Avatar
Default tube seal leaking issue
So after trying new tube seals twice I figure the problem is beyond the seals. My best guess would be a warped valve cover or a crack @ cylinder two. This is the only one leakin. Tried O'Reilly brand then OEM. #2 leaks enough to cause intermittent miss fires. Basically it fills with oil enough to completely cover the plug. Any thoughts?
Old Aug 17, 2014 | 09:45 AM
sstupid's Avatar
10 Year Member
Default Re: tube seal leaking issue
I had a similar issue. I tried 3 different gasket sets, and still leaked into 2 of the 4 spark plug holes. I finally gooped up the donuts with permeates and fixed the issue. You could have leaky cam mount orings, too. There's like 3 of one size and one of another size. You have to remove the rocker girdle to replace them, then adjust valves. See Eric The Car Guy for how to on this job.
Old Aug 17, 2014 | 12:34 PM
nicknack25's Avatar
Jesse M
Honda Civic (2001 - 2005)
Sep 13, 2018 01:42 PM
lgharis
May 23, 2007 06:10 PM
themorphious
Jun 3, 2006 12:14 PM
loup05
Jan 28, 2006 05:30 PM
combustion
15
Apr 11, 2005 02:53 PM
