Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Fog light problem
Old Aug 12, 2014 | 06:53 PM
papi123's Avatar
Default Fog light problem
I don't have power on the fog light I got a new fuse but that didn't work what else can it be
Old Aug 12, 2014 | 10:07 PM
Cjlarson14's Avatar
Default Re: Fog light problem
Have you checked the bulbs to make sure they didn't go out. If not, I'd check w/ a multimeter that power is going to them. Check the relay also; may have gone out.
Old Aug 13, 2014 | 07:28 AM
95jdmcivic's Avatar
There is a number of things that could have gone wrong, check your grounds too. Relay should make a click when you turn it on/off. If not could be a bad switch but likes others said check to make sure there is voltage on the end of the fog, if not trace back to find the short.
Old Aug 14, 2014 | 01:59 AM
Alex91191's Avatar
Not familiar with the wiring harness if there's an extra relay somewhere. Was it the right fuse you replaced?
If all the obvious have been covered, then you'll have to check the bulbs.
Or
It need a new switch.
Old Aug 19, 2014 | 09:11 AM
papi123's Avatar
It was the relay guys thanks
BrayzieEF9
20
Feb 8, 2010 06:08 PM
edsonhp1991
Jun 22, 2009 12:04 PM
B204door
Audio / Security / Video
Dec 21, 2006 04:03 PM
dariusz
Apr 30, 2006 04:51 PM
PetroGuyX
Jun 7, 2004 06:11 PM
