TX 2004 Corvette Z06-Low Miles
Old Aug 12, 2014 | 08:12 AM
onepoint-gsr's Avatar
Default 2004 Corvette Z06-Low Miles
Here is a low mile nicely modified 2004 Chevrolet Corvette Z06 with under 27,600 miles. The vehicle is tastefully modified with the following modifications.
-SLP Cold Air Intake
-Rear differential cooler
-Transmission Cooler
-Brembo Big Brake Kit front and rear
-Magnaflo cat-back exhaust
-Sparco Harness Bar
-Sparco Harnesses
-Sits on 295/35/18 on all four corners. Not Staggered.
The vehicle does needs some work. The paint on the exterior is stained from vinyl graphics. Miscellaneous panels on the vehicle do not match. Bumpers, Passenger door ect. Only in REVERSE it will pop out of gear. You can hold it in gear and drive it in reverse, but if you don't hold it. It will pop out. Driver's speaker grill missing. Exterior passenger lower side air vent missing. Needs tires.
$20,000.
Call or Text. Chris 972-345-3551
Vehicle is located just North of Dallas Texas.
specie
May 6, 2011 10:06 AM
specie
May 4, 2011 11:32 PM
mist sITR
Mar 9, 2010 05:49 PM
squirrels
Feb 18, 2010 09:27 AM
