Accord F20B AC/Fan Issue
Old Aug 11, 2014 | 06:03 PM
TrademarkAccord's Avatar
Default Accord F20B AC/Fan Issue
Hey guys. I'm having an issue with my AC and fans. I have an F20b in a 2000 accord. What's happening is, my AC isn't working properly.
When the AC button is activated, then the AC is off, when the AC button is off, then the AC starts the blow cold. It's simply backwards.
When the AC is blowing cold, the fans don't kick on, then the car starts to idle really low and rough, it will even stall sometimes.
The fans will only kick on when the engine temperature reaches 205 degrees, at that point the idle will even out. Once the temperature drops and both of the fans turn off, the idle is rough again.
Any ideas?
Old Aug 11, 2014 | 07:12 PM
94 accord typeR's Avatar
Default Re: Accord F20B AC/Fan Issue
IACV for the low/rough idle while A/C is on. for the cold air/not cold air issue i dunno
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
Old Aug 11, 2014 | 07:29 PM
tim73's Avatar
Youve gotten something backwards. You need to figure out what the ECM does to turn on the compressor. Either it closes a contact and completes the ground...and energizes the solenoid. Or it closes the contact and completes teh 12V to teh solenoid. Sounds like youve gotten one of the wires backwards.
get a good print...so you can trace back the compressor wires...and then see where the problem is. It may also be a pressure switch, that is actuating backwards(Possibly a normally open and should be a normally closed)
Slash415
Jul 3, 2014 08:28 AM
blackludebosh
Aug 9, 2008 01:33 AM
therobesons
10
Jul 20, 2007 12:04 PM
whitenameseboi
Jul 14, 2004 10:11 PM
