ignition conundrum
Old Aug 11, 2014 | 04:16 PM
Dynorafter's Avatar
Default ignition conundrum
My '90 accord recently quit running - no spark - after a recent visit to the dealer. I have replaced the distributor, alt, plugs, wires, etc. after R&Ring the engine to reseal. tried swapping the ECU with a known good, problem didn't go away or transfer to my other '90 Honda, I cleaned all of the connections & added dielectric grease, still happens, all grounds are clean & tight, just before the engine dies, the tach goes wacky, Crankshaft position sensor, maybe?
Old Aug 11, 2014 | 04:44 PM
BolomanA4's Avatar
Default Re: ignition conundrum
Is it throwing any type of codes? Also did you check the voltage coming out of the battery?
I had a similar issue with my accord, I swapped the battery and haven't had a problem since. Also I would check all power wires and make sure that they are all solid and have no corrosion. If there is corrosion I would recommend having some one with intense electrical experience fix the issue for you as if not done properly it can cause more problems
Old Aug 11, 2014 | 07:15 PM
tim73's Avatar
I would say position sensor, but i thought in these early models, the CPS was in the distributor.
michilina
Oct 8, 2016 07:08 PM
misterix
Sep 29, 2014 01:09 PM
Dazer 1991
13
Jul 30, 2012 06:39 PM
Opponentkhaos
Aug 8, 2008 11:28 PM
