Confirm my OBD2 injectors in OBD1 wiring...please
Old Aug 11, 2014 | 01:43 PM
sixstroke's Avatar
Default Confirm my OBD2 injectors in OBD1 wiring...please
I've got a CRX that was originally OBD0, bought a RyWire harness that effectively converted it to OBD1.
But the injectors use adapters, OBD0 to 1.
As long as I purchase a high-impedance, there shouldn't be any issue going from OBD0 to OBD2 (via my own adapters), without a resistor box. Correct?
Simple questions is simple...just don't want to end up with a bunch of injectors I can't use...
Thanks
Old Aug 11, 2014 | 07:07 PM
holmesnmanny's Avatar
Yes if u dont have a resistor box you just need high impedance injectors.
Old Aug 11, 2014 | 09:59 PM
raverx3m's Avatar
Default Re: Confirm my OBD2 injectors in OBD1 wiring...please
why not use obd1 injectors? theres no real difference unless you gonna go with aftermarket injectors.
Old Aug 12, 2014 | 02:42 AM
sixstroke's Avatar
Because I was having a hard time finding high-impedance OBD1 injectors that were clean but used.
I'm on a budget here :p
thaiphob
Aug 4, 2017 10:40 AM
atarigamer01
13
May 20, 2008 09:23 AM
si 1
Mar 10, 2006 05:23 PM
90 Si SOHC VTec
Jul 27, 2004 01:59 PM
