89 civic si air conditioning reinstall
Old Aug 10, 2014 | 05:11 PM
smfq189ef's Avatar
Icon2 89 civic si air conditioning reinstall
Hello honda-tech community! I own and drive daily a 89 honda civic si and i am wanting to put my a/c back in cause fl weather is to hot with out it ha. I bought my car with a jdm d15b motor in it, it was an oily high mileage motor so i decided to upgrade and swap a d16y8 into it. In the process I removed all compoents for a/c and have been running without it for a long time now. Since then the y8 threw a bearing and i now have a d16y7 in my car. In the process of gathering my a/c stuff i have only found my ac lines and i think a/c bracket not sure though.
My question is, what compressor do i use? I cant remember what i took off. Is there a way to know to buy a sanden or matsushita?
Also i am running the stock y7 crank pulley and my d15 alternator and it eats through belts due to not aligning properly, can i use a d15 crank pulley on y7?
Any info is greatly appreciated!
Old Aug 10, 2014 | 05:17 PM
99teggsr's Avatar
Default Re: 89 civic si air conditioning reinstall
You will be using (most likely) a Sanden TR-70. I am not sure of the model Matsushita. Post a pic of your lines and I can tell you what compressor you use.
I have a bunch of extra AC stuff if you need, AC harness, evaporator, some lines, etc
Old Aug 10, 2014 | 05:46 PM
smfq189ef's Avatar
Here is some pics! ill upload more!
Old Aug 10, 2014 | 05:48 PM
smfq189ef's Avatar
here is more!
Old Aug 11, 2014 | 12:17 PM
rallypoint_1's Avatar
That's the sanden line and bracket.
Old Aug 11, 2014 | 02:25 PM
smfq189ef's Avatar
thank you! will i need to swap my crank pulley to the d15 crank pulley?
ax77
Jul 14, 2015 08:49 AM
guessohw
Dec 3, 2011 09:15 AM
Dialectic
Jul 25, 2006 03:36 PM
boostme1
Feb 22, 2006 12:49 PM
1CiViC1
18
Nov 7, 2003 11:58 PM
