rear brakes replacement issues
Old Aug 10, 2014 | 04:18 PM
spens 91 Ef's Avatar
Default rear brakes replacement issues
im trying to replace my rear brake shoes, i got 1 of them back togethor or think i do but i cannot get the hub to go on. wrong brake shoe size? the shoes look to be almost 1/8-1/4 inch to big the adjuster is almost all the way adjusted in. i thought i bought the smallest shoe size, cars a 92 civic 4 door
Old Aug 10, 2014 | 04:33 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: rear brakes replacement issues
How are we going to know if they're the wrong size, if you never gave us the part number, or told us what or from where you ordered? You also might have them installed incorrectly.
Old Aug 10, 2014 | 04:43 PM
i was looking for some 1 to talk from experience seeing how there seems to be only 3 different shoe sizes, and like stated above i bought the smallest 1 for a 92 civic part number 546 from o'reillys 70.9x1.18 . thats a possibilty i could have installed them incorrectly.
Old Aug 10, 2014 | 05:07 PM
NotARaCist's Avatar
And do you have a CX, DX, EX? Post a pic of them installed. Do you still have the old shoes? Compare the new to the old. Did you compress the brake cylinders when replacing the shoes?
There's no reason they shouldn't fit.
Old Aug 10, 2014 | 05:34 PM
its a lx, the hub says 181mm. i got all three springs in place, i left 1 side how it was to go off of. i didnt compress the cylinders
Old Aug 10, 2014 | 05:35 PM
NotARaCist's Avatar
You need to compress the cylinders. Brake install 101.
Old Aug 10, 2014 | 05:38 PM
is there a way to do it with the shoe assembly on?
Old Aug 10, 2014 | 05:39 PM
thanks for your patience
Old Aug 10, 2014 | 06:08 PM
NotARaCist's Avatar
Sure there is. Just remove the brake fluid reservoir cap, then squeeze the slave piston together. If you have a hard time doing it that way, you can also open the bleeder screw, but if you do that, you absolutely must completely and totally bleed the system afterwards.
john222
Honda Civic (2001 - 2005)
Dec 9, 2020 04:12 PM
92lxsleeper
Aug 14, 2010 07:40 PM
Jdmsoles
Suspension & Brakes
May 17, 2009 09:04 PM
RStoR
Feb 5, 2003 03:42 PM
Auraraptor
Sep 12, 2002 09:50 AM
