H2B in 98 civic - Any advise?
Hey all. Been doing a lot of research on this swap (this will be my first attempt at any type of swapping) and I was just hoping I could get any kind of advise/feedback before I start diving into it. I definitely want to stay N/A. I haven't purchased anything yet because I still have a few questions and I'm in Afghanistan for a few more months. Any help would be greatly appreciated!! Thanks
you're request seems a bit open-ended or broad in scope... I would certainly advise you to continue you're research. this setup has been well documented here and across the web.
if you have more specific questions or concerns, go ahead and post them.
also, it would help if you went into more detail in regards to your goals, intentions and expectations as well as your budget and capabilities. for instance, I wanted to learn to do as much of the work myself as was feasible, have something a little unique but easy enough to find replacement parts for and be extremely cost effective compared to other options with similar power output.
if you're looking for, say, a straightforward swap without many hurdles or challenges then expect to spend a little more upfront on the "kits" and plan accordingly.
Gearhead714
May 26, 2013 02:46 PM
da_coolest
Jul 17, 2009 03:57 PM
