Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Whirring noise! Help!!!
Old Aug 9, 2014 | 03:09 PM
Emilytcivic's Avatar
Default Whirring noise! Help!!!
Hey, I'm new my names Emily (user names gives it away) and I have just purchased my first honda, which is a black civic type r gt, I have a whirring noise that has started and it gets louder as I accelerate, it kinda sounds like a supercharge. Also when I turn her on, it sounds like the power isn't there and then the engine management light is on, the the battery light come on when the car cut out on me. Can anyone help. Makes me sad that I crnt drive her when iv just got her, (full tank of fuel aswell)
Old Aug 9, 2014 | 06:44 PM
av911's Avatar
Default Re: Whirring noise! Help!!!
Car??
Old Aug 9, 2014 | 08:05 PM
DaveSi677's Avatar
Hey Emily welcome to HT!
The CTR you have is it he FN2 by any chance? I'm assuming you are in the UK correct?
Just trying to figure out which one you have
Old Aug 9, 2014 | 08:08 PM
DaveSi677's Avatar
Also the whirring noise could be the AC pulley that is on it's way out. I had this issue on my other civic and it was a royal pain in the **** to get it back in. I would drive me crazy when driving around due to that annoying whine lol.
Old Aug 10, 2014 | 02:36 AM
Hey, yes I am in the uk, it's fn2, I just tried to start it and It keep cutting out, and the battery light keeps come on,
Old Aug 10, 2014 | 08:37 AM
97emsedan's Avatar
Sounds more like the alternator is seized on its crank. Your car isn't making voltage to run its systems. By the way, the engine in your car is the same as the North American Si engine, the K20 Z3.
Anyways, get your alternator looked at, and if required, replaced.
See you on CivInfo maybe?!! Cheers.
Old Aug 10, 2014 | 09:24 AM
Is it going to be expensive?
Old Aug 11, 2014 | 02:38 AM
97emsedan's Avatar
Shouldn't be too bad. You get a refund of sorts from the old alternator as it can be remanufactured at certain shops.
Most likely around £90-100 for the new unit.
Old Aug 11, 2014 | 03:40 AM
Someone said it could be the vtec? I'm so confused as it's got no power, (what a type r should have anyway) and cuts out while driving, and keeps sayin oil pressure is low.
Old Aug 11, 2014 | 05:09 PM
97emsedan's Avatar
It won't be the VTEC system, that runs on oil pressure and cam timing, the lack of power is from your charging system and that you are getting a weak pulse to your spark plugs.
Have a good shop look at your alternator output. That will be the clincher.
Old Aug 12, 2014 | 09:27 AM
Iv been told that they need to change the timing belt and tensioner a guna cost £1300 Grrhhhh
Old Aug 12, 2014 | 04:01 PM
97emsedan's Avatar
Oh crappers....how many miles on the clock?
Old Aug 13, 2014 | 08:54 PM
DaveSi677's Avatar
No timing belt needs to be changed on our engines... we have a timing chain!
How much mileage does you engine have?
Old Aug 13, 2014 | 08:55 PM
DaveSi677's Avatar
they are suppose to last at least till about about 150k miles at least...
Old Aug 16, 2014 | 08:13 AM
It's done £40,000 so not much at all. Oil pump might be damaged lets hope it hasn't damaged anything else, say oil pressure low, and cuts out. X
Old Aug 16, 2014 | 10:08 AM
97emsedan's Avatar
Dave, I presumed she meant the timing chain. Not a big deal. The previous owner must have flogged the car, or it wasn't maintained faithfully.
A timing chain and tensioner changeout at 40k miles ( UK, remember) is premature, but not outside the realm of real.
Old Aug 16, 2014 | 10:34 AM
DaveSi677's Avatar
ya either poor maintenance or major abuse... and these engines can take abuse as long as you are on top of thing.
It's a shame really when you see things like this!
Old Aug 16, 2014 | 06:10 PM
97emsedan's Avatar
True that
Old Aug 18, 2014 | 06:29 AM
Thank u guys, I find out her fate tonight. I will let u all know! X
Old Aug 18, 2014 | 05:02 PM
97emsedan's Avatar
Best of luck. Safe motoring.
Old Aug 18, 2014 | 05:18 PM
DaveSi677's Avatar
Best of luck!
Old Aug 22, 2014 | 01:38 PM
Hi guys, the car needs a new engine, the sump was damaged and they welded it, and there is shrapnel in the engine that has caused the oil pump to mess up, the previous owners r a car hire company that have a service and mot station on site, they got the number plate changed over last month it had a privet number plate, do you think I have a leg to stand on if I try and get then 2 cough up?
Old Aug 22, 2014 | 01:53 PM
97emsedan's Avatar
You could try. It seems that they knew something was up and unloaded the car without a proper going over.
Their own MOT station means they can write their own inspections. Not cool. I would go after them, but beware, it can get costly. How much does a recycler charge for an engine over their?
Old Aug 22, 2014 | 02:23 PM
It's £1500 for new engine then about £700 for labour ( I'm so annoyed, they are a big company so I don't they will want the hassle, I could also threaten them with the local papers,
Old Aug 22, 2014 | 06:33 PM
97emsedan's Avatar
Probably easier to get the new lump and be done with it. At least you can keep the gearbox.
