B16a2/Gsr trans full complete swap( Wisconsin)
Old Aug 9, 2014 | 10:42 AM
hctim00's Avatar
Default B16a2/Gsr trans full complete swap( Wisconsin)
Mitch.
Lacrosse wisconsin
6085181866
Like the title says I have a complete b16/Gsr trans swap for sale or trade for k series engine and trans. Price 2500obo
Mileage is around 90k on motor unsure on trans. Runs and drives perfect. Compression numbers are 180-175 across.
Goods
New gates racing blue timing belt and tensioner
New water pump
Plm narrow header
Blackworks cam gears
Fully ported skunk 2 intake manifold
Skunk2 68mm throttle body
Bdl fuel rail
Upgr8 fpr
Hasport billet mounts
Rywire tucked harness.
B&m race shifter.
New driver axle
Brand new oem clutch, flywheel and pressure plate
New password jdm cam seal
Ipg parts block fittings for catch can
Fuel pressure gauge
Literally will come with everything you need to drop in and go
Cons
Oil drain plug leaks a little
2nd gear is kinda hard to get into at high rpms
Only have a obd1 ls ecu to run it
Bolts on cam gears hit the inner timing cover so it makes an annoying sound. Just need to pull the inner timing cover off and that'll take care of it
Motor is in car still and will happily run it for so buyer can here it run
Like I said 2500obo or trade for a running k series engine and trans. Obviously doesn't have to be complete
Old Oct 13, 2014 | 02:58 PM
hctim00's Avatar
Default Re: B16a2/Gsr trans full complete swap( Wisconsin)
Still up for grabs. I fixed the oil pan, inner timing cover, and now have chipped p06 with stock b16 base map on it. 1100 takes it. Will not come with mounts or harness.
HiBoost Whiteboi
Feb 5, 2009 05:17 PM
iH8RICERZ
Northern California (Sales)
25
Jun 26, 2008 05:04 PM
Boosteddb8
May 20, 2008 09:00 AM
9krpm
Nov 15, 2004 10:44 PM
