AC Compressor cycles on and off
Old Aug 9, 2014 | 08:16 AM
Vega0821's Avatar
Default AC Compressor cycles on and off
I have a 92 civic ex and my ac blows pretty cool but when Im driving your can hear it turn on and off and feel it. The car moves so much. What can it be?
Old Aug 9, 2014 | 08:27 AM
Former User's Avatar
Default Re: AC Compressor cycles on and off
It's normal.
Old Aug 11, 2014 | 09:28 AM
Vega0821's Avatar
its not normal trust me. I know it does that but you dont feel it every 5 seconds.
Old Aug 11, 2014 | 09:49 AM
redyute's Avatar
Low on freon will cause that. Did you hook up some guages to see where the pressure is at?
Old Aug 12, 2014 | 04:29 AM
Jump the thermostat. Does it still cycle?
Old Aug 12, 2014 | 12:55 PM
JDM-EJ698's Avatar
Sounds like its low on freon. Check that first.
Old Aug 12, 2014 | 12:58 PM
The refrigerant would have to be extremely low to make the compressor cycle off. This is inconsistent with the fact that the A/C blows cold.
Old Aug 12, 2014 | 01:02 PM
JDM-EJ698's Avatar
Well he said its "blowing cool". So If it blowing cold it might something else, But if its blowing cool then it might be low.
Old Aug 12, 2014 | 01:08 PM
I agree.
Old Aug 13, 2014 | 05:27 PM
redyute's Avatar
Originally Posted by RonJ@HT
I agree.
x10 my point exactly
Old Aug 14, 2014 | 12:08 AM
AR_96's Avatar
My 96 ex does the exact same thing. Has extremely cold air but compressor cycles every 5-10 seconds. And I checked freon and it's right where it's supposed to be. Sorry I'm no help, I kinda just got used to it haha
Old Aug 14, 2014 | 04:32 AM
JDM_SOHC's Avatar
I had this same problem as well, but mine only cycles off when I come to a stop.. Once I get in motion again it starts blowing cold air... A/C problems are the worst..!
Old Aug 14, 2014 | 07:53 PM
philipxhuff's Avatar
Possibly a bad condenser fan motor. If the high side pressure gets too high the compressor will cycle on and off to regulate the pressure. It would've worse at a stop with no air flow though the condenser. I've also seen a/c systems with air or moisture in the system and it causes high pressure on the high side of the system while driving down the road or at a stop. Also wouldn't hurt to maybe check the gap on the clutch.
Old Aug 14, 2014 | 07:54 PM
Would be worse*
Old Aug 17, 2014 | 01:27 PM
civicvx1992's Avatar
Maybe overfilled too, too much pressure in the system the switch will shut down the the compressor once the pressure drops it will start again. Need a gauge to see for sure.
Old Aug 18, 2014 | 12:22 AM
Vega0821's Avatar
I took it to my local mechanic and it has the right amount of freon buy he said that whoever installed my compressor had put too much Pag Oil in the compressor. Would that cause the issue?
Timbogates
Honda Civic (2006 - 2015)
Aug 20, 2018 02:33 PM
E30LS1
Honda Civic (2001 - 2005)
Jul 9, 2014 09:40 AM
lakerschamp2000
19
Apr 24, 2009 12:37 PM
disboitrung
Aug 5, 2008 07:28 PM
Civic Racer X 7
Aug 23, 2007 08:42 AM
