2001 Honda Accord possible blown headgasket? Peanut butter type liquid?
Old Aug 7, 2014 | 08:52 PM
swifity's Avatar
Post 2001 Honda Accord possible blown headgasket? Peanut butter type liquid?
Hey all, I just bought a 2001 Honda Accord from a private party a couple weeks ago. I took it about 400 miles a week after I bought it for a little road trip. I made sure all the fluids were filled and topped off. But about 3 days after I got back to my hometown. I pulled into work Saturday morning and saw that my engine had white smoke. So I popped the hood and I had a very tiny slit in my upper radiator hose, and that was shooting anti-freeze all over my engine causing the smoke. But I then looked at my coolant reservoir and it was filled with the brown stuff. Looked like a very watery peanut butter. Very thick. I am not sure what it could be, I was told it is most likely a blown head gasket. My transmission oil is still red and fine, as well as my oil still brown and not peanut butter looking at all. The car did not shoot out white exhaust and it did not ever over heat. So I am quite puzzled on what this issue is. It ran smooth and had a strong engine. It is a 2001 Honda Accord 4-cylinder vtec with 160,000 miles on it. As far as I know everything mechanically is stock.
Any suggestions on what it could be? My mechanic said he would fix the head gasket for around $600-700.
Here are some pictures below!
Old Aug 7, 2014 | 09:14 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 2001 Honda Accord possible blown headgasket? Peanut butter type liquid?
Milkshake is usually indicative of a blown head gasket, oil may be blown/leak into the coolant passages, but water may not.
Have a compression and/or leak down test done on the engine.
Old Aug 7, 2014 | 09:17 PM
swifity's Avatar
so it is highly likely I have a blown head gasket?
Old Aug 7, 2014 | 10:16 PM
holmesnmanny's Avatar
a compression test would confirm it but it seems almost sure it is given that goo
Jrojas007
Nov 7, 2017 05:08 PM
JenreneeH
Jul 17, 2017 01:18 AM
newtohonda-tech
Jul 19, 2014 07:24 AM
revemoto
Sep 12, 2012 07:47 PM
