90 CRX- bogging, cutting out under load.
Old Aug 7, 2014 | 07:14 PM
RED_REX's Avatar
Default 90 CRX- bogging, cutting out under load.
Car has ran fine up until a few days ago. It has started to bog, cut out, buck under heavy throttle. Can drive fine up to speed in city and highway but as soon as I give it throttle to pass or accelerate hard it does its thing.
Specs.
b18c1/b16a head
skunk2 intake
Skunk2 tb
rc 550 injectors
buddy club spec IV cams w/ matching cam gears
supertech valve train
12:9 supertech pistons w/eagle rods and eagle crank
Things I've checked/changed.
distributor
injectors
ecu
plugs
wires
iacv
map
tps
grounds
main fuel relay
new fuse box
bled the coolant system
compression checked good on all 4
no codes thrown.
I'm sure it's something simple, I'm just stumped. Any help would greatly be appreciated.
Old Aug 7, 2014 | 10:09 PM
hammergunner's Avatar
Default Re: 90 CRX- bogging, cutting out under load.
i sure all sensors are receiving proper voltage, and fuel system stays at pressure when pushing the gas, your injectors might be squirting gas and not spraying when they completely open
Old Aug 9, 2014 | 11:57 AM
RED_REX's Avatar
I will be checking to see what fuel pressure is while driving tomorrow.
Old Aug 9, 2014 | 06:23 PM
sstupid's Avatar
10 Year Member
Cutting out under load is almost always a spark issue. If you only "checked" the wires.....change them.
Old Aug 9, 2014 | 07:08 PM
br8crumb's Avatar
air filter......... seriously... the most over looked thing lol
ZWK
Jul 15, 2008 10:42 AM
BG-Teg
Apr 9, 2007 07:58 PM
Aro321
Jan 21, 2007 01:13 PM
cartunes
Jan 22, 2005 11:28 AM
EGHatchy
Jul 14, 2002 11:25 AM
