NEED HELP ASAP - d15b swap in '99 ex
Old Aug 5, 2014 | 01:41 PM
CM5Falco's Avatar
Default NEED HELP ASAP - d15b swap in '99 ex
a friend of mine blew his original y8 motor in his '99 ex sedan & had to pick up a d15b since it was the only motor available in our area & we're having a small dilemma with the belts.
he kept the original ac comp & ps pump from the y8 so we just wanted to know if the y8 spec belts would fit the d15b crankshaft pulley.
I looked up the part numbers for both the d15b & y8 and confirmed that they are different.
This south FL summer is really kicking off hard this year and having no AC or PS is not fun lol... it is 96 degrees and extremely humid today.
Any input is appreciated, thanks guys.
Old Aug 5, 2014 | 01:53 PM
andoxviii's Avatar
Default Re: NEED HELP ASAP - d15b swap in '99 ex
There are a bunch of different D15B engines. Which one is this?
And to answer your question, yes it fits (assuming you are using the good D15B engine...I am unsure of the other ones but I think it fits them all)
Old Aug 5, 2014 | 01:56 PM
CM5Falco's Avatar
jdm d15b
thanks man!
tony_2018's Avatar
Fish Twig
You might have to sit in the parking lot because you'll be going back and forth to the shop to test belts. Do you know what yr that d15b came from? Have you compared both cranks to see what the differences are?
Old Aug 5, 2014 | 01:57 PM
andoxviii's Avatar
Originally Posted by CM5Falco
jdm d15b
thanks man!
But that is what I am trying to tell you...there are several different JDM D15B engines. Which one is this?
Old Aug 5, 2014 | 02:04 PM
andoxviii's Avatar
If you have the "good one" as I mentioned above (which is, of course, the OBD1 92-95 JDM D15B VTEC) then read this thread:
http://www.d-series.org/forums/gener...-vtec-faq.html
^^ Lots of great information.
Old Aug 5, 2014 | 02:05 PM
andoxviii's Avatar
Why would he need to do that...?
Old Aug 5, 2014 | 02:10 PM
tony_2018's Avatar
Fish Twig
Because there's probably no sure fire way to determine what the engine came from so telling him to get so and so belt might end up being the wrong belt, so instead going back and forth to the auto store just be prepared to sit in the lot for a bit. It doesn't take long to tighten belts.
Old Aug 5, 2014 | 02:12 PM
andoxviii's Avatar
It doesn't matter where it came from.
All that matters is which one it is. And since they all look different, it's not difficult to know which you have.
Old Aug 5, 2014 | 05:55 PM
CM5Falco's Avatar
it is the 92-95 non vtec sorry should've specified
EX-T
Nov 15, 2009 01:27 PM
killa4lyfe
Jun 16, 2008 12:59 AM
uo959
Jan 15, 2008 07:55 PM
