h22a in 92' accord problems
Ok, so I swapped an h22a into a 92 accord, it was in a 90' accord previously, I did the swap in the 90' as well, the swap went good, I'm getting a code 8, I replaced the dizzy with a brand new one but I still get the code 8, tachometer also doesn't work, any suggestions?
You can put a 30 amp fuse in the plug for external coil, or jump it code 8 is the Tdc sensor, replaced distributor with a brand new one and still get the code
