Accord Ex will not start. One click. No turning over.
Old Aug 3, 2014 | 04:34 PM
Richteje's Avatar
Default Accord Ex will not start. One click. No turning over.
Hello,
I am new to the forum, and I've been having an issue with my 2000 Honda Accord ex. 4 cylinder. The car has been having some issues starting for the past few months. After I had taken it to Monroe (horrible idea) that had explained that they were not sure what was wrong but said it may have a bad starter. So I decided to YouTube starter replacements and preformed a replacement myself. After installing the starter (and before tightening the battery terminals, I had them resting on the battery the car started!) So I had turned the car off and tightened the terminals. After doing so I went to turn the car on for a test drive and had no luck starting. The cars lights work, and battery has been tested and are considered in perfect working order. I'm stumped. The car will click (once) in the 3rd starting position, and the radio will turn off. The car will not turn over. Any ideas?
Old Aug 3, 2014 | 07:43 PM
Otis B. Firefly's Avatar
Default Re: Accord Ex will not start. One click. No turning over.
Sounds like a short or bad fuse or relay did you check both fuse boxes? One under the hood and the one inside near the driver side door?
Old Aug 3, 2014 | 07:48 PM
Richteje's Avatar
I've check the one under the hood. I missed the other. I'll take a look. Where would it be located?
Old Aug 4, 2014 | 07:46 AM
tim73's Avatar
I would make doubly sure, your battery connections are clean. Both the battery posts, and inside the terminals. Use a wire brush until they shine. Then add a little conductive grease. I cant tell you how many times this problem has bitten people.
Old Aug 4, 2014 | 11:41 AM
You only can access the interior fusebox if you have the Driver side door open there should be on the side of dash. I hope this helps!
Old Aug 4, 2014 | 06:06 PM
Lost Again's Avatar
I can't understand why people don't get this.
Listen to "tim" - you have a bad connection.
Old Aug 4, 2014 | 08:02 PM
holmesnmanny's Avatar
If you knew how to do a voltage drop you can verify for sure it's the battery terminals. There are several how-to's on youtube.
TeeBoneEX
Dec 27, 2017 12:08 PM
pyrosee
Jan 27, 2015 06:44 AM
misterix
Sep 6, 2011 10:23 AM
Nessal
Jan 21, 2006 03:40 PM
pecusio
Aug 16, 2004 06:50 AM
