O2 sensor wiring
Quick question, I am wiring my o2 sensor. I have two blacks, one white and one green. All colors match up but my question is are both blacks for the same thing? Like in other words, there is no way I can mix em up?
Reason I ask is because when I did both my primary and secondary 02 sensors, both were plug n play. have you read this thread? http://www.s2ki.com/s2000/topic/1029...placement-diy/
The O2 sensor uses a resistor as a heater. Since the resistor is not directional in the flow of current, even if you switched the heater wires at the O2 sensor, it will still work.
Primary and secondary regular O2 sensors heater wires are same principal.
Those are the heater wires (e..g, the two whites and the two blacks). On the connectors, the terminal no. 3 wire is the heater control wire from the PCM and the terminal no. 4 wire is the fused battery power coming from the under-dash fuse box when in ON or START. The O2 sensor uses a resistor as a heater. Since the resistor is not directional in the flow of current, even if you switched the heater wires at the O2 sensor, it will still work. Primary and secondary regular O2 sensors heater wires are same principal.
Thanks.
http://www.lambdasensor.com/main/mcolours.htm
The S2000 wiring on the engine harness side connector should be terminal no. 1 (white), terminal no. 2 (Grn/Yel), terminal no. 3 (Blk/Yel), and terminal no. 4 (Blk/Wht).
Since one side of the wires are not stock wiring (i.e., the 2 whites, one black, and one gray), you should probably use this guide to match them up: http://www.lambdasensor.com/main/mcolours.htm The S2000 wiring on the engine harness side connector should be terminal no. 1 (white), terminal no. 2 (Grn/Yel), terminal no. 3 (Blk/Yel), and terminal no. 4 (Blk/Wht).
So since I have the two heater wires, there really isn't a way that I can mix them up right? Whichever way will be fine? Or will it throw a code and can I just switch the two whites? Or two blacks.
The engine harness connector wires:
Terminal no. 1 (White) - Primary Heated O2 sensor input (PCM/ECM)
Terminal no. 2 (Grn/Yel) - Sensor Ground (PCM/ECM)
Terminal no. 3 (Blk/Yel) - Ignition Power in ON or START
Terminal no. 4 (Blk/Wht) - Heater Control (PCM/ECM)
Terminal no. 3 and 4 wires are the heater wires.
patastinky
Jul 19, 2005 01:24 PM
