F22B new rings
Old Aug 2, 2014 | 10:12 PM
seedycd5's Avatar
Default F22B new rings
Hi guys,
I have a 96 accord which has gathered a rather large, 345,000kms. It's burning minimal oil but still going strong.
Is it a good idea to put new rings in to gain back a few hp and stop the oil being burnt?
Thanks!
Old Aug 2, 2014 | 11:10 PM
NerfGunner420's Avatar
Default Re: F22B new rings
you'll have to hone the block at least along with rod bearings, its a cheap ghetto rebuild haha i wouldn't do it tho
Old Aug 3, 2014 | 08:05 AM
MAD_MIKE's Avatar
MM Gruppe B
Originally Posted by seedycd5
Hi guys,
Thanks!
Do a compression check. If the compression is fine then the rings are most likely OK. Pull your spark plugs as well, if they have oil on them or the spark plug tubes have oil in them then the O-ring gaskets for the spark plug tubes are probably leaking. Replace them.
Old Aug 3, 2014 | 09:58 AM
Lost Again's Avatar
And the poor old pcv never gets the attention it needs these days.
blackeg
Nov 22, 2011 08:05 AM
rocko5845
37
Nov 29, 2010 08:21 AM
YoWTF
May 27, 2010 10:39 PM
doublej7584
Feb 17, 2008 07:10 PM
Mr. Softee
Nov 16, 2001 05:25 PM
