GA **EG Drag Car Shell w/ Chromoly Cage**
Old Aug 2, 2014 | 03:10 PM
kte324's Avatar
Default **EG Drag Car Shell w/ Chromoly Cage**
My plans have changed and I have lost interest in this project.
1993 Honda Civic Cx
Clean Clear Title
10 Point Chromoly Cage built by CCE to NHRA Specifications
Switch Panel and Wiring Harness for B-series
5 Gallon RCi Fuel Cell
36mm Hubs
RCi Aluminum Drag Seat w/ EG Seat Rails
PCI Bronze Front Suspension (Solid Aluminum) Bushings
All Other Bushings Are Prothane
New Balljoints, Inner & Outer Tie Rods, Wheel Bearings, Brake Rotors & Pads
Extended Wheel Studs
New Fenders
Rolling on stock suspension and steel wheels
**I have the doors, front and rear bumper, two rear hatch glass, side skirts, and the bottom part of the rear hatch.**
I also have a extra set of door windows.
Here are some other stuff included with the car:
New Bosch 044 Fuel Pump Mounts
New D-series Flywheel
New Taylor Cut-off Switch 1032
New Fuel Lab Post-Pump Fuel Filter 81801-1-8an
New Earl Pre-Pump Fuel Filter 230208ERL
New Prothane Bushings Front Lower Control Arms
New Prothane Front & Rear Shock Mount
New B16 OEM Intake Gasket
New Eg Condenser, Drier, & Used Condenser Fan
New 5 Aluminum -10an Bungs
Used B-series Spool
Used B16 Vtec Valve Cover w/ Spark Plug Cover
Flywheels 1 Used D-series 1 Used B-series
Used Axles 2 Driver’s EG/EK Manual 2 Passenger’s DC Manual
Used Speed Sensors VSS
Used Shift Linkage D-series
Used Stock EG Radiator
Used EG Blox Rear LCA (Need Bushings)
Used D16Y8 Vtec Solenoid
3-Post Used Driver’s Engine Mounts 1 D-series
Used EG Cluster w/Tach Auto
Used 12" Slim Fan
Used T-Bracket 2 DC Integra 1 EK Civic
Used Msd SCI Ignition Box
Used Cast Iron B-series Log Turbo Manifold
Used D16Y8 OEM Springs & Retainers
Price: $1800 or best offer. Will consider trades. Text/Call 706-627-9865 for more info or pictures.
Old Aug 6, 2014 | 02:43 PM
kte324's Avatar
Default Re: **EG Drag Car Shell w/ Chromoly Cage**
Bump.
Old Aug 13, 2014 | 05:31 PM
kte324's Avatar
Bump.
Old Aug 21, 2014 | 07:03 AM
kte324's Avatar
Bump
Old Aug 21, 2014 | 03:05 PM
toyomatt84's Avatar
Sanji
Please see here: http://hondamarketplace.com/announcement.php?f=42&a=43
Nerologic
Apr 30, 2014 02:53 PM
madpipr
Mid-Atlantic (Sales)
Feb 3, 2010 05:11 AM
miraclehonda
Apr 4, 2009 04:08 PM
Chain Driven
Mar 27, 2007 06:05 PM
UncleBen'sRacing
Aug 4, 2003 01:06 AM
