FL 95 EG / Built Single Cam / SiR / Spoon / Skunk 2 / Custom Color - Oil Slick ETC
Model:Cx Eg hatchYear:1995
Title: Clean
Contact
321)805-1095 name is Randy for more info or pictures/questions feel free to askPrice:$4500
Miles:8000 on motor and 15 xxx on chassis
Dyno Numbers:175whp 112 tq
Gas type: e85
Video of the car running:
Motor d16z6
Ported polished head cwpence
Comp cam
Springs retainers
Adjustable cam gear
Arp head studs
Cometic head gasket
Stock bore
Custom pistons 14.1 compression
LS rods with arp rod bolts
Crower wrist pin bushing
Cleavite coated main bearings
Cleavite coated rod bearings
And thrust bearings
New water pump
New timing belt
New oil pump
Bizy equal length header
Skunk2 pro series intake manifold
Type r throttle
Aem fuel rail
470cc injectors
Aem fuel filter
Z6 transmission
Clutch master 6 puck clutch
Solid motor mounts
New axles
Engine bay
Custom oil slick color
Wire tuck
Brake tuck
Fuel line tuck
Neochrome bolts
Aluminum radiator
Slim fan
Silicone hoses
Exterior
New headlights
New 50\50 tails
Vision clear corners
Sir front lip
Custom color
Spoon rear wing
Ek custom fit side skirts
Spoon mirrors
Civic rain guards
Interior
Gsr black full interior
Jdm center console
Ex cluster
4.5 radio TV dvd aux ect
Sub amp
10" sub
Pioneer mids and highs
Bertini classic wood 1 of 50 steering wheel
Suspension
Full gsr rear disc brake.
Hawk pads all around
Kyb strut s
Ground control coilovers
Front and rear camber kit
Beaks rear bar
Silver lower control arms
16x9 25 offset front 15 rear
Keiskin 5spoke with oilslick lips
missing couple things as i remember i will update the post thank you
this car makes me moist. if i had the garage space for this, id be on my way to Florida right now. bump for one of the only non ridiculously overpriced cars on here.
