Please help : Spoiler Brake light
It is an led bar you should be able to find one on ebay on the cheap. I dont know if they are reliable or not, but an easy fix you just have to look. An i assume a shortie phillips would help too..
If you look at between the trunk lid and spoiler, you should see where the LED bar ends. There should be a seam, a little bit below that should be either 3-4 screws, remove those and the panel will come off, giving you access to the LED bar, pull it out a bit and disconnect it. Then replace it with a new bar.
