97 hx crank no start
Old Aug 1, 2014 | 07:24 PM
ArtyTheKid's Avatar
Default 97 hx crank no start
Swapped a d16y5 (hx) motor into my 97 ex. Drove it for 4 days woke up on the 5th day and crank but not start. Motor ran great had no problems for 4 days now idk.
Car has new; ngk plugs, ngk wires, cap, rotor, and just picked up a new distributer. Still no start. Not getting any spark out of any of the wires or the coil but I know for a fact this distributer works I put it in my friends ex and his car started and ran fine. I checked all of my grounds, all the
fuses under the hood / dash. I try ed using a different battery. Tryed popstart jumpstart nothing. Tryed a different ecu I know that's good but same crank no start. I'm going crazy what could be the problem?
Old Aug 1, 2014 | 08:03 PM
Former User's Avatar
Default Re: 97 hx crank no start
CELL codes?
Does the fuel pump prime?
Old Aug 1, 2014 | 08:57 PM
UncleD's Avatar
Main relay? Do you hear a click when you turn the key to the on position?
Old Aug 2, 2014 | 06:18 AM
ArtyTheKid's Avatar
There's no click whatsoever. Also I Tryed using another main relay and I got the same result. Even Tryed re soldering the joints but nothing.
Old Aug 2, 2014 | 06:19 AM
ArtyTheKid's Avatar
Originally Posted by RonJ@HT
CELL codes?
There is codes I haven't pulled them yet. Also idk what u mean by fuel pump priming?
Old Aug 2, 2014 | 06:42 AM
grumblemarc's Avatar
The Grumpiest
Turn key to the ON position. You will see the CEL go on and then off after about two seconds and hear the main relay click. During this time you will hear the fuel pump. located under the back seat, make some noises. That noise is the fuel pump priming.
And PULL THE CODES!!! All you need is a paper clip.
Old Aug 2, 2014 | 11:35 AM
NerfGunner420's Avatar
check voltage at the distributor plug
SOLFUL
10
Apr 28, 2019 06:10 AM
CaptCanadia
Sep 15, 2015 08:32 AM
ArtyTheKid
Feb 6, 2015 02:08 AM
ReVeNgEd-SoN
May 28, 2010 10:41 PM
icepack
Oct 13, 2008 02:26 PM
