DPFI to MPFI OBD0
I am doing the DPFI to MPFI OBD0 swap in my 90 DX and have the B7 intake/injectors , pm6 ecu, A6 distributor and injector clips. Where can i get the round distributor plug? Does anyone sell these new or do i have to find a used one? Thanks.
Junkyard or you can see if they got something that suits your needs for male and female connector set at say radio shack (or similar electronic store).
you dont need the round plug but it helps you can use the old square one and sodder on to the A6 dizzy then just get 2 single wire connectors for the cam sensor wires. you could even just sodder them together just need to cut wire if u need to remove dizzy. the junk yard is the best place to look. look for the A6 wire harness and just cut it. you can also steal it off other honda's just make sure it has the same wire count and its round honda plugs are more or less universal to the size across all models.
Thanks, i noticed that the TPS plug is the same and also the O2 sensor plug. The B7 intake didnt have the map on the throttle body so im wondering if the DX map sensor on the firewall will work for now?
I thought that was the map on the passenger side firewall with the rectangular plastic cover that keeps falling off? 90 DX. There are a couple valves or dashpots under that i thought were part of the map. My bad. Any other crap that i can trash with the EGR valve?
88crxdxfastwhip
May 30, 2008 10:31 PM
mahatma
Jun 9, 2006 04:14 AM
