changing manual transmission fluid
Old Jul 31, 2014 | 05:59 AM
bristolhonda's Avatar
Default changing manual transmission fluid
So i accidentally added MTF to where the arrow points in this picture. Its not the correct fill hole! Is this a problem??
I added two quarts of genuine Honda MTF to this opening. The car shifts smooth. I hear no problems. everything seems to be ok.
Im just trying to make sure this is ok to add fluid to this possible alternative hole???
thanks
Paul
Old Jul 31, 2014 | 07:41 AM
JDM_SOHC's Avatar
Default Re: changing manual transmission fluid
that's actually higher then where you should of added it, hense why you have a shitload of fluid coming out of it and stained on ur transmission...
This is an H series, but same exact concept..
Old Jul 31, 2014 | 08:12 AM
slogfilet's Avatar
If you added two full quarts, you will be a bit overfull (I believe 1.9 qts are needed). Get the car flat and crack the fill bolt... it will drain to the proper level.
You're likely not in any danger, but letting it naturally level out makes adding the right amount pretty much fool-proof.
Old Jul 31, 2014 | 09:37 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I wouldn't recommend driving with it overfull. May seem okay now but who is to say what the long term effects are.
Drain the excess from the proper fill hole and call it a day. Once it is a dribble from the fill hole on level ground, it's filled to the proper level.
Mike8ike
Transmission & Drivetrain
Jul 30, 2013 05:20 AM
Mike1995HondaPrelude
Sep 1, 2007 07:38 AM
Cypher0117
May 3, 2005 06:47 PM
Y2KGreenGSR
Sep 28, 2001 12:11 PM
