94 accord tire size?
Old Jul 30, 2014 | 06:50 PM
onunezp's Avatar
Default 94 accord tire size?
Hello ppol,
i have a question, i want to know if i can put 235 60 r15 on my stock 94 accord? will they rub against something? the car is not lowered or anything.
thanks
Old Jul 30, 2014 | 07:01 PM
accordturb96's Avatar
Default Re: 94 accord tire size?
Those are fairly wide and tall for an accord. The height should be okay, but the width regardless of drop may be excessive. I usually see people stop at 225. My question to you is why such a different size tire? Your speedo will be all off, might even effect the end result of the gearing and power
Old Jul 31, 2014 | 04:57 AM
Fitz Williams's Avatar
10 Year Member
It sort of depends on your wheel offset. The car came with 195/60/15. When you go to 235 the tire also gets taller as well as wider. Maybe you should be looking at something like 235/50/15 and a different set of rims. Question is also how much tire do you want sticking out past your fender.
jdmCD695
Oct 6, 2008 10:40 AM
T3k C
Nov 29, 2006 04:30 PM
jdm94accord
May 7, 2006 08:16 PM
blackpearlv6
Apr 21, 2006 11:42 AM
