2000 Honda Civic has weak spark
Old Jul 29, 2014 | 06:34 PM
JW2000CivicDX's Avatar
Default 2000 Honda Civic has weak spark
I really need some help with my car. This has been a 6 month battle that I am losing. I will be a brief as I can. Car ran great for years. Nothing but problems last 6 months. I fought an overheating problem for months but seem to have it ok for now. Now I have a recurring weak spark problem. I have replaced the fuel pump and filter as well to elimate a fuel issue. Car wouldnt start and I narrowed it to weak spark. New coil fixed it for about 3 weeks then came back. New module fixed it for 2 weeks now is back. After testing the coil and module as good I put a brand new distributor but same problem. It will not start and has a yellow spark. I have cleaned and checked all the ground wires. I have new plugs and plug wires. I am concerned it might be a bad ECU however it is not creating any codes. It was starting harder each day then quit starting. I have tested everything I can find info on exept the ECU. Any suggestions would be greatly appreciated.
Old Jul 30, 2014 | 12:41 AM
Yajhershey's Avatar
Default Re: 2000 Honda Civic has weak spark
Have you check your alternator to see how much voltage it is making?
Old Jul 30, 2014 | 04:50 AM
09chaplak's Avatar
Loves Tossing Salad
Sounds like you've covered most of the tests regarding ignition but have you checked the sticky's regarding weak spark/no spark diagnostics? https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-how-test-spark-troubleshoot-spark-problems-2919450/
I would make sure you went over everything in this section, you might have already but based on the information given, "narrowed the problem" we can't assume you went over every step in the link given. After going over, or letting us know that you've gone over everything in the link it'll be easier to provide next steps.
Old Jul 30, 2014 | 02:36 PM
Thank you for the link. Unfortunately I have done all of this. After my coil and module tested good this time and still had weak spark with all 4 plugs I decided it must be something inside the distributor itself. I already had a new cap and rotor. Now I have a new complete distributor with new everything internal but same weak spark on all 4 plugs. I dont know if the ECU is giving the distr what it needs at this point.
Old Jul 30, 2014 | 02:41 PM
I really dont think I have an alternator problem. Engine cranks great and has been for the last 2 weeks while I have tried just about everything imaginable to this car. And I also have a new head gasket, water pump, timing belt, radiator, fuel pump, fuel filter, thermostat, fan switch, etc etc. This car has been a train wreck lately.
Old Jul 31, 2014 | 04:24 AM
09chaplak's Avatar
Loves Tossing Salad
You're on the right track and from here you'll want to check this out, http://s639.photobucket.com/user/Ron..._5583.jpg.html Main relay could be the cause for the weak spark at this point. Hopefully this will be your last step in pinpointing your problem.
Old Jul 31, 2014 | 05:04 PM
Got it. Thank you again. I have this and will follow up.
Old Jul 31, 2014 | 05:28 PM
I did an initial quick test of the relay and it passed. I will do some more thorough testing however. Another question if it is my ECU that is bad I have found lots of them for sale but all the numbers do not match exactly. Are the last numbers a serial number of some kind and will not match? I have a 37820-P2E-A92. 6A 1201-364250. Its the 364250 part. All of find have different numbers here but the rest is the same. They all say they fit my car.
Old Jul 31, 2014 | 09:00 PM
mithious's Avatar
What were the results of your alternator test?
Old Jul 31, 2014 | 09:34 PM
NerfGunner420's Avatar
have you checked voltages and good grounds at the distributor plugs including the +5 volt reference?????
Old Jul 31, 2014 | 09:59 PM
Dense147's Avatar
key switch
Old Aug 3, 2014 | 06:20 AM
09chaplak's Avatar
Loves Tossing Salad
Correct me if I'm wrong HT, but the designations you want to be concerned with are the second two sections of the ecu listings, just as long as you have the 37820 there(all ecu's have this code). P2E is mostly referred to as the year/trim, this being 96+ DX make sure that's the correct application. And the following section, origin of make/trans/revision number, A92 is the automatic revision. Any further testing updates?
Old Aug 3, 2014 | 11:06 AM
Sorry I have been away for the weekend. I will resume work now. Thanks for the info. I will run some more tests.
Old Aug 3, 2014 | 06:55 PM
Update: Car is fixed. Went to some salvage yards and found a main relay and an ECU. The main relay didnt change anything however the spark changed with the ECU swap. Engine started fine and ran good. after final timing set running better than it has in a long time. Thanks to everyone for the assistance. Its been long road with this Civic.
Old Aug 4, 2014 | 04:30 AM
09chaplak's Avatar
Loves Tossing Salad
Good to hear, and what better car to take you down the road than a honda?!?!
PSHuertas
Dec 2, 2013 06:25 PM
j4yzn
Aug 24, 2009 12:45 PM
Honda FTW
Sep 12, 2008 04:01 PM
ex_ricer
Aug 14, 2008 02:14 PM
itrintegra
Oct 3, 2007 02:34 AM
