1994 Honda Civic CX Hatch w/GSR Swap (Not Cranking)
Old Jul 29, 2014 | 10:52 AM
94CivicHatchGSR's Avatar
Default 1994 Honda Civic CX Hatch w/GSR Swap (Not Cranking)
Please chime in if you can help...this is my only car and daily driver.....
Was driving this morning and then parked car. Got out for a few minutes and tried to start it and it wouldn't start.
-I turned key and I only heard a "click" under the dash
-Car won't crank at all (doesn't even try to crank)
-Still appears to have charged battery as radio/lights work fine
Is this:
1. Bad starter
2. Bad Main Relay
3. What else would this be??
Thank you for any ideas or help - I need to fix this TONIGHT!
Old Jul 29, 2014 | 11:15 AM
DylanGSR_eh9's Avatar
Default Re: 1994 Honda Civic CX Hatch w/GSR Swap (Not Cranking)
Does your fuel pump prime? And is the *click* from the engine bay or dash?
If so then tap your starter and see if it will try to crank the motor, when my GSR did this I replaced battery and starter (needed a battery anyway) hope this helps!
Old Jul 29, 2014 | 11:16 AM
Also don't rule out your battery just yet, lights/radio don't need very much battery power to work.
Old Jul 29, 2014 | 04:21 PM
Thanks I'll check both at the parts store... Quoted $120 for rebuilt lifetime warranty
Old Jul 29, 2014 | 04:25 PM
Also....if the main relay was bad Wouldn't the car still NOT RUN if I push started it?
I just push started it again.
Old Jul 29, 2014 | 09:26 PM
Ok... So, the issue was the wire going to the solenoid backed off the connector. I pushed it back on and bingo car started.
Old Jul 30, 2014 | 12:04 AM
... Damn wires lol
Old Jul 30, 2014 | 07:55 PM
Originally Posted by DylanGSR_eh9
... Damn wires lol
Yep!
I pushed started my car 3 times when all I had to do was push the 1 wire back on. It looked like it was on due to the wire covering... Returned starter to store got my $120 back
Hondacrf
Jun 16, 2017 04:13 AM
95-del-sol
Jul 15, 2013 08:12 PM
p_en03
Jan 24, 2008 05:10 PM
solk1dd
Jul 23, 2007 06:25 PM
AspectIndustries
Aug 22, 2004 07:35 AM
