Safe to use GSR Crank Pulley on ITR?
Old Jul 29, 2014 | 05:45 AM
beanss's Avatar
Default Safe to use GSR Crank Pulley on ITR?
Hello H-T, I've read a few articles through the search function, but have not found a solid answer.
My dilemma: Picking up an ITR swap, but the owner decided to put an aftermarket pulley on it (Ran for 2 months, then totaled the car). I refuse to run this pulley even though it still has grooves for A/C and P/S. I have access to a GSR crank pulley, but I would have to buy a ITR pulley new since I cant find one used. I just want to be on the safe side with this motor. Will I be okay with the GSR pulley? Thanks.
Old Jul 29, 2014 | 07:23 AM
J.Berta's Avatar
It will be fine to use the gsr pulley on it.
Old Jul 29, 2014 | 07:36 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Safe to use GSR Crank Pulley on ITR?
I could be wrong, but I think the ITR pulley is just a bit under driven for the higher RPM capability of that engine. You should be fine with a GSR pulley. In any even the ITR pulley is about $20 cheaper than the GSR if you do purchase new.
Old Jul 29, 2014 | 08:34 AM
spAdam's Avatar
Loved
Community Favorite
Correct.
Professional Products makes stock replacement ones for both gs-r and itr sizes btw. Available from Summit, et al. I have about 45k on mine and it's doing just fine.
Old Jul 29, 2014 | 09:05 AM
beanss's Avatar
Thanks for the replies everyone, I'll run the GSR pulley (it'll be free). Atleast for the moment, and I may get a professional products pulley in the future. Because I did read about the ITR pulley being slightly smaller, and under driven.
'00_GSR/R
Jan 25, 2009 11:41 PM
pootie.teng
Jan 9, 2007 11:38 AM
hideandgoseiki
Jul 20, 2005 09:44 AM
asefi944
Apr 12, 2005 05:11 AM
Hard2Find
May 14, 2002 10:09 PM
