K24z7 in em2 lots of progress crank sensor problems
Old Jul 28, 2014 | 05:53 PM
Atc350x's Avatar
Default K24z7 in em2 lots of progress crank sensor problems
Hey, I have a 2002 civic I've spent hours doing this swap used rear custom mount and used 36mm hubs for the axles also have the prl intake manifold adapter kit with an 8th gen intake manifold and hybrid racing throttle body, digital Dakota box only thing I ran accross was the crank sensor I did re wire it for the other location I am using a 2002 rsx engine harness (changed all sensors over except for crank shaft sensor) I heard these crank shaft sensors pulse 50 times instead of 10 I was going to use kpro but I geuss that wouldn't work for me. I was curious if I could use a k24 cog off an older k24 engine and maybe customize the timing cover or even if I could use an older k24 crankshaft?
Natie Barnard
Honda CR-V & Element
Jan 16, 2019 06:38 AM
tony755
Oct 28, 2018 05:26 PM
kndj30
Honda Civic (2001 - 2005)
Feb 11, 2010 03:58 AM
Brad_and_the_acc
Jun 16, 2009 01:33 PM
