95 LX drivers cv boots torn but passenger OK; replace both axles anyway?
Old Jul 28, 2014 | 08:10 AM
Skryblz's Avatar
Default 95 LX drivers cv boots torn but passenger OK; replace both axles anyway?
I have a 1995 LX w/a D15B7, the drivers side axle has both inner and outer CV boots torn but it is not clicking yet; passenger side has no rips. I know it is more economical to just replace the axle as a whole, my question is since the car has 154k miles on it should I replace both sides anyways?
Same question about wheel bearings, they aren't squealing at all, just have lots of miles on them. Can I add grease to them, or since they are OK don't worry?
I'm about to replace the bushings/upper control arms/balljoints/end links in the front end and since I'm tearing it all apart I figured it might be worth it.
Old Jul 28, 2014 | 09:41 AM
visiblystealthy's Avatar
Default Re: 95 LX drivers cv boots torn but passenger OK; replace both axles anyway?
If you're considering doing it, and are already going to have it all apart, do it all. No need to do the bare minimum then have something go out in the next x,000 miles. Also, make sure you get an alignment done afterward.
tamadrummer1120
Oct 13, 2009 07:48 AM
compo1
Apr 24, 2007 03:14 PM
James
Aug 30, 2004 11:49 AM
lahight
Sep 3, 2003 01:26 AM
