d16z6 oilpressure sender wiring help!
Old Jul 27, 2014 | 02:54 PM
Alex_S's Avatar
Default d16z6 oilpressure sender wiring help!
Hi guys, i've been hooking up my d16z6 swap now. Both interior harness and engine harness is from an Si. For some reason my engine harness doesnt have the Yellow/red wire to the oilpressure sender on the back of the engine block.
Now i just figure i'd run a new wire to the ecu, but i'm having trouble finding the correct pin to wire it to.
http://technet.ff-squad.com/wiring/o...schematics.gif
That is the schematics i've been using, does anyone know to where i should run the wire?
Thanks!
/Alex
Old Jul 27, 2014 | 02:57 PM
grumblemarc's Avatar
The Grumpiest
Default Re: d16z6 oilpressure sender wiring help!
What engine harness are you using?
Old Jul 27, 2014 | 02:59 PM
Alex_S's Avatar
It's from an Si ( d16z6 )
Old Jul 27, 2014 | 03:00 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
that should be a body harness wire, the ecu might see it too, but it generally goes straight to the cluster, and there may be additional wires tapped off of it
Old Jul 27, 2014 | 03:08 PM
Alex_S's Avatar
Ah i see. What does it acctually do? cause the engine starts and runs with no problems.
only have a code 43.
Old Jul 27, 2014 | 03:12 PM
it causes your oil pressure light to come on if the oil pressure is too low, usually Honda will keep it simple, wire from the switch to the light, then anything else that uses it taps off of that, if the oil pressure is too low that switch grounds and the light comes on, it not being hooked up is why your oil pressure light doesnt come on when you first turn on the key
Old Jul 27, 2014 | 03:20 PM
Alex_S's Avatar
Aha. Thanks alot for the help!
JDM_CAM23
Dec 9, 2011 01:32 AM
Crimson_Tide
Jan 11, 2006 06:59 PM
KamikazeSol
Sep 11, 2003 05:36 AM
KamikazeSol
Sep 10, 2003 07:59 PM
