95 Del Sol steering creak and squeak
Old Jul 26, 2014 | 03:03 PM
Johnoolo's Avatar
Default 95 Del Sol steering creak and squeak
Whenever i turn the steering wheel while driving under 20 mph it crraks and sqeaks very loudly like a vibration of something rubbing together
My first thought when it started was power steering pump turn the car off and turn the wheel steel squeaking
Second i drained the powersteering fluid replaced it and added a little marvel mystery oil to it it stopped sqeaking for about 3 miles and its squeaking again
New ball joints car lowered on coilovers an anyone enlighten me on this subject?
Old Jul 26, 2014 | 06:22 PM
Haaarrrrryyy's Avatar
Default Re: 95 Del Sol steering creak and squeak
new upper or lower balljoints? id check any pivoting points having to do with steering the car. check your tie rod ends, making sure that theres no dirt/crap where the joint comes in contact with the knuckle, and the boots are well in tact, and lubricated. try your best to isolate the noise
Old Jul 26, 2014 | 10:51 PM
Johnoolo's Avatar
Ball joints are new tie rod ends are original oem i feel the vibration through the steering wheel which makes me believe the rack may be worn out
Old Jul 26, 2014 | 11:06 PM
shotoutacc0rd's Avatar
Have you ever played with your tie rods? There's a ball joint in there, perhaps its worn out?
Old Jul 28, 2014 | 07:25 AM
Johnoolo's Avatar
That could be it never replaced
Old Jul 28, 2014 | 11:02 AM
Johnoolo's Avatar
That could be they were never replaced?
buzkilr
May 26, 2011 12:21 PM
Rudy84
Sep 15, 2010 11:21 AM
Synbios
Mar 14, 2007 01:39 PM
jabroni95gsr
Feb 13, 2003 04:12 AM
