NY 93 civic hatch b18 turbo BUILT
selling only due to purchasing a house and need the money to put down towards down payment!
1993 civic cx hatch
unknown mileage on body due to cluster being changed
HAS SALVAGE REBUILT TITLE!! due to minor front end collision before i bought it. has been fixed since and has no issue being registered anywhere. still drive it now.
Interior
aem air/fuel gauge
autometer boost gauge
auto meter oil pressure gauge
k Tuned shifter with skunk 2 ****
aem boost solenoid switch
power window conversion
Exterior
was painted black a few years ago, not perfect can be touched up.
has a couple small bubbles starting on rear quarter panel
front bumper has scratch on it from car bumping into it.
ccc racing street wing
konig wheels (NEW)
2 new tires and 2 tire @ 50%
black housing headlights
dynamic performance rear diffusor
battery kill switch on hatch
Suspension
tien street coil overs in front
black works front upper control arms
energy suspension bushings in front end
new lower ball joints
new outer tie rods
new manual steering rack
fresh alignment
blox drag coilovers in rear
blox lower control arms
avid racing traction bar set up
Motor
B18 ls motor
81.5mm bore
cp 9.0-1 pistons
eagle rods with arp bolts
acl bearings
arp head studs
cometic head gasket
b16 oil pump
gates racing timing belt
supertech valve springs and retainers
ferrea competition 5000 series valves
crower 402-t turbo cams
stock cam gears
edelbrock intake manifold
skunk 2 70mm throttle body
ccc racing catch can with vented valve cover
ngk spark plugs and ngk wires
morose oil pan
Turbo kit
blue ridge motorsports top mount t3 manifold
precision 5857 turbo
tial 38mm wastegate
3" downpipe to 3" exhaust
tial style bov
precision 750hp intercooler
avid racing solid motor mounts
Transmission
jdm gsr tranny- oem lsd
competition stage 4 clutch
oem flywheel
Fuel
precision 1200cc injectors
walbro 255 fuel pump
aem fuel rail
aem fuel pressure regulator
tuned on aem version 1
all parts on motor were installed new and have less than 100 miles on them. everything works perfectly fine
car dyno'd 395hp 295tq @ 17psi on pump gas
has plenty more in it
ran 11.58 at dragstrip granny shifting breaking everything in.
most likely forgot stuff ill post as i remember.
price is 8k firm
heres the video from the track-
no joy rides will be given!! don't come with any other offers not interested
1993 civic cx hatch
Interior
aem air/fuel gauge
Exterior
konig wheels (NEW)
Suspension
new outer tie rods
fresh alignment
Motor
B18 ls motor
81.5mm bore
cp 9.0-1 pistons
acl bearings
arp head studs
cometic head gasket
b16 oil pump
stock cam gears
morose oil pan
Turbo kit
tial 38mm wastegate
tial style bov
Transmission
oem flywheel
Fuel
aem fuel rail
price is 8k firm
92db8gsrb17
Aug 29, 2010 10:21 AM
