I have a few things for sale car parts, mini bikes, race stuff just alot.
I will be posting up parts as I go with prices and pics.
Doodlebug frame powdercoated black with x8 front wheel powdercoated burgundy brand new front and rear tires omb rear sprocket adapter billet throttle 1/4 turn Predator arc rod 20 over billet flywheel billet side cover no governor no oil sensor custom ported head milled with 32 28 custom Manley 5mm valves new champion rockers dual springs with new retainers and keepers chromoly push rods isky 360 cam block has been notched for clearance new head gasket tall valve cover with new thick gasket all stainless steel hardware bully 3 disc clutch tillotson 360 cam and billet intake port matched arc heat shield/chain guard custom stainless steel pipe made by me all tig welded 1 of a kind new gold chain has a tach as well seat was redone with new material and foam has a catch can everything was bought brand new and has very little use bike does over 80mph $1500 firm NO TRADES AT ALL
87 inches a little over 7 ft of -8 stainless steel braided line with 1 90 and 1 45 on it this was in my race car $125 firm
Oem 2000 SI headlights just need to be cleaned $135 firm
Brand new slave cylinder for any hydro trans $10
Azusa frame with 8 inch trip stars new tires new drum brake new predator 6.5 stock fresh oil has a doodle bug seat new clutch this bike has been rode 5 times max it just sits $300 firm
Gx200 polished crank arc rod lightweight billet flywheel billet side cover new flat top piston no governor no oil sensor custom ported head milled with 32 28 valves new valve guides champion rockers dual springs with new retainers and keepers chromoly push rods isky 360 cam block has been notched for clearance new head gasket tall valve cover with new thick gasket all stainless steel hardware block was painted and is beautiful never ran everything is brand new all it needs it a clutch and carb setup $725 firm that's what the parts cost alone not Including porting or labor can include a Tillotson 360 carb and port matched intake with pulse fitting and fuel pump for $240 extra NO TRADES AT ALL
Y8 manifold $40 firm
d16z6 arp head studs brand new never torque $85.
I have 2 b series aem fuel rails one is in great condition silver without fittings $75 the other one still works fine was just shaved a little i want $40 for that one the 2 bolt on regulators $75 each the universal one $85 all prices are firm plus shipping and paypal fees.
Brand new hondata manifold gasket for gsr just no package pic was prior to me tossing the package $30 shipped in us
used hondata manifold gasket for gsr 20 shipped in us
tial 38mm 2 bolt wastegate unsure of what spring it has $100 firm
Intercooler and piping came off my daily dc made 614 whp with this setup no leaks and some clamps are missing i will take measurements if interested has a hks black bov $250 plus shipping and paypal will not seperate kit.
autometer phantom nitrous and water temp gauge i cant find sensor for gauge what you see is what you get $35 for nitrous $20 for water gauge pod $15
type r steering wheel will fit eg and dc and ef $150 firm thew velcro works just takes some finesse
3 alternators all work great just had them tested $35 each
duralast gold battery $75
nrg short hub for ek and quick release i have a momo steering wheel as well that was installed for 2 days i cant find the horn but i have the plate that holds the horn button $225 firm i prefer not to separate but will for the right price
JAZ 1 quart fuel cell with built in mounting studs -8 on bottom -6 on side $50
brand new slave cylinder never used not oem $10
D16Y8 Intake manifold what you see is what you get $40
ARP D16Z6 Head Studs Brand new I opened them, and put them on the block hand tight and realized they were for a z6 and not a y8
2000 Civic SI OEM Headlights just need to be cleaned $150
Interstate battery $40
-8 fuel feed line with 1 90 and 1 45 fitting on it 87 inches long $125
NRG Traction bar eg dc $150
Funny his only rating is from me. That was from when I barely knew him. He was planting his seed and thinking ahead. Very skilled at his con.
Please see here: http://hondamarketplace.com/announcement.php?f=42&a=43
p3anutboi
25
Oct 2, 2011 09:32 PM
