Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Private Label MFG Power Driven OIL CATCH CAN / BREATHER TANK RACE KIT
Old Jul 25, 2014 | 11:27 AM
sublimnal's Avatar
Default Private Label MFG Power Driven OIL CATCH CAN / BREATHER TANK RACE KIT
*** PM ME FOR FORUM PRICING ***
__________________________________________________ __________________________________________________ ______
Private Label MFG Power Driven OIL CATCH CAN / BREATHER TANK STREET / RACE (UNIVERSAL))
STREET TANK
PM ME FOR HONDA-TECH PRICING
BASIC INFO:
The PLM oil catch can race kit/breather tank is designed for mild horsepower motors. The breather tanks are internally baffled to keep the oil inside the breather tank and also designed to replace the factory PCV system and vent to atmosphere. The kit utilizes three ports, 2 ports for the valve cover and 1 ports off the back of the block(OPTIONAL). Which vent at wide open throttle and drain back under vacuum. The catch cans are CAD designed and CNC Press Punched using the latest state of the art technology.
Note: B20 blocks don't have the stock black box, so you don't need the block plug.
1x polished/ catch can with 3 -10 male bungs with mounting bracket
10 ft. of AN-10 hoses
1x AN-10 45° degree fittings
2x AN-10 90° degree fittings
3x AN-10 swivel seal hose ends
2x AN-10 weld-on aluminum male bungs for valve cover ventilation lines
1x 1 -10 block plug adapter
1x 1 AN 10 billet aluminum hose separator
1x breather filters
RACE/STRET TANK
BASIC INFO:
The PLM oil catch can race kit/breather tank is designed for high horsepower B-series or K-series motors in EG/EK/DC chassis (universal). The breather tanks are internally baffled to keep the oil inside the breather tank and also designed to replace the factory PCV system and vent to atmosphere. The kit utilizes six ports, 4 ports for the valve cover and 2 ports off the back of the block. Which vent at wide open throttle and drain back under vacuum. The catch cans are CAD designed and CNC Press Punched using the latest state of the art technology.
This catch can kit is designed to mount in the factory battery location (as a simple clean install) on all 92-00 Civic and 94-01 Integra chassis's, but is universal for other vehicles too)
1x AL6061 CNC press-punched catch can (BAFFLED) (COMES IN BRUSHED ALUMINUM)
15 ft. of AN hose
10x AN-10 straight swivel seal fittings
1x AN-10 hose separator
4x AN-10 weld-on aluminum male bungs for valve cover ventilation lines
2x block port fittings for the back of the block with sealing washer
1x block plug
3x breather filters __________________________________________________ ______________________________
Old Jul 29, 2014 | 12:09 PM
sublimnal's Avatar
Default Re: Private Label MFG Power Driven OIL CATCH CAN / BREATHER TANK RACE KIT
TACO TUESDAYS~~!
Old Jul 30, 2014 | 01:54 PM
sublimnal's Avatar
Hump day bumping it ~!
Old Aug 1, 2014 | 11:14 AM
sublimnal's Avatar
TGIF~~!
Old Aug 4, 2014 | 10:47 AM
sublimnal's Avatar
Case of the Mondays ~!
Old Aug 6, 2014 | 10:30 AM
sublimnal's Avatar
Old Aug 6, 2014 | 10:06 PM
jxnguyen's Avatar
pmd
Old Aug 7, 2014 | 11:09 AM
sublimnal's Avatar
Originally Posted by jxnguyen
pmd
replied!
Old Aug 8, 2014 | 10:09 AM
sublimnal's Avatar
TGIF~~!
Old Aug 11, 2014 | 12:13 PM
sublimnal's Avatar
Old Aug 13, 2014 | 10:26 AM
sublimnal's Avatar
Old Aug 14, 2014 | 09:47 AM
sublimnal's Avatar
Thirsty Thursdays~~!
Old Aug 15, 2014 | 10:20 AM
sublimnal's Avatar
Tgif ~!
Old Aug 18, 2014 | 11:30 AM
sublimnal's Avatar
Old Aug 19, 2014 | 09:01 AM
sublimnal's Avatar
Taco Tuesdays~!
Old Aug 20, 2014 | 10:15 AM
sublimnal's Avatar
Old Aug 21, 2014 | 10:23 AM
sublimnal's Avatar
Old Aug 22, 2014 | 09:54 AM
sublimnal's Avatar
Tgif ~!
Old Aug 25, 2014 | 11:28 AM
sublimnal's Avatar
Old Aug 26, 2014 | 11:56 AM
sublimnal's Avatar
Taco TUESDAYS~~!!
Old Aug 27, 2014 | 10:36 AM
sublimnal's Avatar
Old Aug 28, 2014 | 10:33 AM
sublimnal's Avatar
Old Aug 29, 2014 | 09:30 AM
sublimnal's Avatar
TGIF~~!
Old Sep 2, 2014 | 11:20 AM
sublimnal's Avatar
Taco Tuesdays~!
Old Sep 4, 2014 | 10:30 AM
sublimnal's Avatar
