Whats wrong with my 93 del sol fuel pump?
Old Jul 24, 2014 | 04:36 PM
DarkGriffin3156's Avatar
Icon6 Whats wrong with my 93 del sol fuel pump?
After i got my 93 del sol from my parents i encountered problems with the fuel pump. It wouldn't always work and so i replaced it. This fixed the problem for a short time but now the new pump rarely turns on and the car never turns over. Any suggestions of what is wrong and the solution to the problem will be greatly appreciated.
Old Jul 24, 2014 | 04:50 PM
OptimisticWay's Avatar
Default Re: Whats wrong with my car?
What model Del Sol do you have with what transmission? All original or something swapped? If so, what has been swapped?
Does the engine no longer turn over? Or the starter engages and turns the engine but the engine will not fire.
What makes you think that the new pump rarely turns on?
Old Jul 24, 2014 | 04:52 PM
NotARaCist's Avatar
I never narc'd on nobody!
Probe the pump wire with a voltmeter - do you get voltage with the key turned to ON(II)?
If you don't, remove and test your main relay. If it fails, repair or replace it.
If you do, what fuel pressure are you getting at the filter?
Old Jul 24, 2014 | 05:05 PM
andoxviii's Avatar
Yeah I agree...test your main relay. Especially if the pump priming is intermittent.
Old Jul 25, 2014 | 10:36 AM
delsolintegra's Avatar
It's your ECU.
The capacitors are shot from age, humidity/moisture and heat.
The fuel pump priming circuit becomes a intermittent problem until it finally totally fails. This problem is so common especially now at the 21 year old age of these ECU's. Borrow a known good ECU if you want to check it out.
Start calling junkyards to find one. Auto and stick are different ECU numbers.
Check the label on the ECU.
Old Jul 25, 2014 | 10:44 AM
egsleepercivic's Avatar
main relay fix y0!
http://techauto.awardspace.com/mainrelay.html
Old Jul 25, 2014 | 04:45 PM
tony_2018's Avatar
Fish Twig
Originally Posted by delsolintegra
It's your ECU.
If he is stating that his fuel pump isn't priming than the main relay should be the first thing to inspect. Along with ignition wiring next, go from there OP.
Old Jul 25, 2014 | 04:57 PM
S!K TEG's Avatar
Default Re: Whats wrong with my 93 del sol fuel pump?
I had the same problem once, turned out my main relay was going out.
Old Jul 26, 2014 | 03:10 AM
I agree he should check the main relay first (it's easy) but the 93 del sol specifically is a little leak box. The ECU area passenger floor compartment is a water collection area. The fender seams and the roof rubber trim leaks to the ECU area is a real problem. Because of this specific model car ( and if the OP lives in a humid climate like Florida) I would guess ECU. I chased this problem myself in my 93 sol over a year and a half. I changed fuel pumps (twice), main relays, ignition switch. When I replaced my ECU I hung a plastic cloth over the ECU like an umbrella. The outer housing of my ECU had condensation corrosion. The capacitors specifically C14 on the ECU pcb are the first to go.
Good luck.
Old Aug 10, 2014 | 05:51 PM
It turns out it was my main relay and now it starts up every time.
Old Nov 21, 2021 | 08:30 AM
CwNiehaus69's Avatar
Icon4 Re: Whats wrong with my 93 del sol fuel pump?
my 93 dx with the D15B7 has been doing the exact same thing. will try the main relay b4 going to more expensive options.
so, my next question is,,, Where is the MAIN RELAY, LOCATED??? ANYONE???
Old Nov 21, 2021 | 05:33 PM
tamboo's Avatar
10 Year Member
https://www.youtube.com/results?sear...993+main+relay
will pm you a link to fsm helm manual, cant post it here. 8(
David93DelSol
15
Nov 7, 2017 11:59 AM
philztheone
40
Apr 27, 2015 06:57 AM
amfer03
May 9, 2009 09:32 PM
almostjdmeg
Jul 21, 2008 05:19 AM
nafreak
Aug 10, 2006 05:17 PM
