Stroker D16
Old Jul 24, 2014 | 09:55 AM
StuckInTexas's Avatar
Default Stroker D16
Before I get any farther into my planning, can I use my stock ODB2 ecu with a D17 crank and pistons?
I tried searching with some key words but I haven't found anything, is it possible to just use my stock one? The compression would be about the same.
I've read about b18 ecu's running b20s, a little lean yeah but those had 138cc difference, this one would be only 73cc.
Our motors come from Honda running a little rich anyways, wouldn't this be possible?
Maybe get a FPR and gauge if needed?
Thanks
Old Jul 24, 2014 | 11:15 AM
93egSLEEPER's Avatar
Default Re: Stroker D16
Anything besides a stock motor should be tuned.
Old Aug 7, 2014 | 09:29 PM
Yeah buy if the Comp is almost the same, just a little longer stroke.
Old Aug 7, 2014 | 09:33 PM
....tune it. Changing stroke will shift the power band which will shift fueling/timing maps.
Hell even a stock motor from the factory can benefit from a tune. Why ask if you just want to argue about it and have your mind made up?
Old Aug 8, 2014 | 02:21 AM
TracerAcer2.2L's Avatar
Anti-GDD White Knight Simp
Just get a basemap chrome tune from rywire or something. Its so close, a basemap should run it fine.
Sounds like cost may be a factor for you, which is why I'm suggesting this. Of course Hondata or EMS is the way to go if cost isn't a concern
Old Aug 8, 2014 | 03:48 PM
bigG's Avatar
yes u will need a tune i have these a few times
Old Aug 8, 2014 | 06:23 PM
crazes's Avatar
Moderator
Curious what your reasoning is for stroking it out?
StuckInTexas
Engine Management and Tuning
15
Jul 27, 2014 06:13 PM
mekanism
Oct 11, 2005 04:51 PM
mugenhatchie
Mar 27, 2005 08:35 PM
stealthhatch
Feb 9, 2005 09:24 PM
B18B EK
Feb 7, 2005 09:29 PM
